Question about Car Audio & Video
02 altima wiring for all three harnesses - Car Audio & Video
    Scholar:
  • 127 Answers
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
02 altima wiring for all - 623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Posted on Dec 31, 2010
02 altima brakelightd don't work but signals and taillights too
if the signal lights work then the wiring and socket and obviously the bulbs are good which leaves the brake light switch or wiring at the brake switch is bad.
Sep 23, 2014 | 2002 Nissan Altima
Can a 1994 nissan altima wiring harness ,engine and trans fit a 1995 nissan altima
Engine will, not sure about the harness. You can swap parts off the old engine.
Jul 02, 2011 | 1995 Nissan Altima
How to connect pioneer deh-p3600 car stereo electrical codes to 02 nissan altima harness
Electrical codes? You should buy a wire harness that goes into your factory harness. Any audio shop to include Best Buy should have them. Usually the only reason a company doesn't have them is because they either ran out, or don't have the room to stock them. If that's the case, any of those stores should be able to go out an order one for you.
Apr 13, 2011 | Car Audio & Video
How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
  1. Remove or disconnect the following:
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
  1. Install or connect the following:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Apr 05, 2010 | 1999 Nissan Altima
Fuel injection fuse
you have a short in the fuel injector harness to ground. you will need to look the harness over for chaffs or broken wires and make sure they aren't touching metal or another wire in side the loom.
Mar 04, 2010 | 2005 Nissan Altima
'97 nissan altima, brake lights not working, wire
Lets keep it simple if the wiring harness is in good condition lets not look at that... first check your fuse if the fuse is good... check for power... if you have power coming and going from the fuse then check your brake switch ( located under the dash) attached to brake pedal. Please make sure your light bulbs are both good also. If your brake light switch is good and you have tried everything else it is either going to be in your 4 way switch or wiring harness
Aug 23, 2009 | 1995 Nissan Altima
I am trying to wire a sony xplod deck to my 2001 altima and need to know which wires connect to each other and steps of doing that.
Hello charlieramir,
The wiring color code for the 2001 Altima can be found here. Your Sony deck should have come with a wiring harness and an installation sheet (or a page in the user manual) that shows the color and function of each wire. You simply match up the functions of each wire on the harness with the appropriate wire on your vehicle.
A simpler and more professional installation is achieved by using a vehicle-specific wiring harness that plug into your Altima's wiring. Such a wiring harness allows you to make all of the connections while seated at the dining room table or other well-lighted location instead of the limited space area behind the dash. The Scosche NN03B/NN03 seems to be the correct harness for your Altima.
Hope this helps.
Jul 02, 2009 | Sony Car Audio & Video
Poor fuel economay, fuel mixture to rich
the upstream sensor is the probable cause (ahead of catalytic converter)
Aug 05, 2008 | 2002 Nissan Altima
Car Audio & Video Logo
233 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
