Question about Nokia N95 Cellular Phone
No signal network problem
Show me circuit diagram of fixing this problem
  • dudevikky Jul 11, 2008
    My N72 is not detecting the network
  • 3 Answers
Your phone seems to be locked by some operator , please unlock it , it will solve ur problem
Posted on Jul 10, 2008
My guages stoped working and transmition seems to be slipping in my 2001 shevy silverado 4.8
Well ronnie do you know how to do automotive electrical testing with a volt meter ? How to read an understand a wiring diagram ? Would think not to be a relay problem because other thing's would not work as well ! More then likely a loose ground or something on that order ! Plus you must mean Ignition . 1 relay , because there isn't a eng.1 relay . Ign. 1 relay powers the PCM - engine computer , fuel injectors , the TAC - electronic throttle control module . Do the instrument cluster lights still work when the gauges quit ? Looking at power distribution diagram I see a engine 1 fuse but has nothing to do with the instrument cluster . Supply's B+ voltage to the maf sensor , EVAP system , CAM sensor , IAT sensor , fuel pump relay ! Could be a communication problem on class 2 data bus . All the modules on the vehicle share information on the class 2 bus . The gauges get thier info from the PCM over this data network !
Engine Coolant Temperature Gauge
The IPC displays the engine coolant temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gauge defaults to 75°C (160°F) or below when:
• The PCM detects a malfunction in the engine coolant temperature sensor circuit.
• The IPC detects a loss of class 2 communication with the PCM.
Fuel Gauge
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gauge defaults to empty if:
• The PCM detects a malfunction in the fuel level sensor circuit.
• The IPC detects a loss of class 2 communications with the PCM.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates.
Reviewing the fuel system description will further explain how the system functions. Refer to:
Speedometer
The IPC displays the vehicle speed based on the vehicle speed signal from the PCM. The IPC receives the vehicle speed signal via a discreet wire. The IPC uses the vehicle speed signal circuit (4000 pulses/mile) from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 km/h (0 mph) if a malfunction in the vehicle speed signal circuit (4000 pulses/mile) exists.
Tachometer
The IPC displays the engine speed based on the engine speed signal from the PCM. The IPC receives the engine speed signal from the PCM via a discreet wire. The IPC uses the engine speed signal circuit (2 pulses/engine revolution) from the PCM in order to calculate the engine speed. The tachometer defaults to 0 rpm if a malfunction in the engine speed signal circuit (2 pulses/engine revolution) exists.
Transmission Temperature Gauge
The IPC displays the transmission temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the transmission temperature. The transmission temperature gauge will default to 40°C (100°F) or below if:
• The PCM detects a malfunction in the transmission temperature sensor circuit.
Voltmeter
The IPC displays the system voltage as detected at the ignition 1 input of the IPC. When the engine is ON, the gauge should be between 10 and 16 volts.
The only one that has a hard wired sensor is the oil pressure gauge.
Engine Oil Pressure Gauge
The IPC uses the engine oil sensor signal to determine the engine oil pressure. The oil pressure sensor signal circuit is hard-wired to the IPC. The engine oil pressure sensor signal to the IPC is a variable resistance ranging from 0-90 ohms. A sensor resistance of 1 ohms will display as 0 psi (0 kPa) and a resistance of 88 ohms will display as 80 psi (550 kPa). The Check Engine Oil Pressure indicator will be displayed in the message center if the IPC detects a low engine oil pressure.
Does this one drop out also ? quit working
I would suggest that you take an have the IPC checked for DTC'S - diagnostic trouble codes , NOT OBD 2 engine codes , these are different an need a professional type scan tool .
You could check G103 for being loose . G103
On the left rear of the engine block . Also pull the instrument cluster out an check connection at the back of IPC . Check power an ground circuits at the PCM as well . You can fine wiring diagrams here
http://www.bbbind.com/free_tsb.html Enter the vehicle info . year , make , model an engine . under system click body an acc. then under subsystem click on instrumentation .Click the search button , then click the blue link . At the top of the diagram it shows B+ power supply , The connectors on the back of IPC , A,B , plus the pin # an color wire .
PCM power and ground testing avi
How To Use Multimeter Test Car Ground Video 3
Intermittent Electrical Diagnostics with Rich Peterson
Apr 10, 2017 | Cars & Trucks
My 2004 corvette turn signals works sometimes other times they don't is there a fix
Testing the turn signal electrical circuit is the way to the fix > Videos on youtube , automotive electrical testing . Find a wiring diagram at Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts also how to use an read wiring diagrams .
Feb 26, 2017 | Chevrolet Corvette Cars & Trucks
I have a 1992 Mercury Cougar LS I have no turn signals but I have wipers I checked the fuses but there is nothing going on
Did you check for voltage at the turn fuse circuit, use a test light. Even if the fuse is good if no voltage, the circuit is still dead. The fuse circuit goes hot with the key on.
With the use of a wiring diagram to show wire colors, it is possible to check voltage going into the steering column and coming from the steering column for turn signal voltage.
Nov 03, 2015 | Mercury Cars & Trucks
I recently buy samsung galaxy core ,i faceing network prob in my mobile . it recive poor network signal. i using vodafone network.in my indoor home it show me poor network when i insert same network sim in...
go to settings , then network , then mode , then make it manual and select vodafone...... if it doesnt work after that also then u shall visit the samsung outlet
Nov 06, 2013 | Cell Phones
Net work problem and find it circuit diagram of samsung gtc3510
Hello:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 31, 2013 | Cell Phones
1978 Cadillac Eldorado turn signal lights show parking illu & tail lights keep dark
see the diagram and fix it.Test the fuse,lose connection, dirty, corrosion, oxide.continuity.
God bless you
Sep 28, 2012 | Cars & Trucks
I have a nokia 5030 but signal nothing
First Option:
Secend Option:
Aug 13, 2012 | Nokia 5030 Cell Phone
Wiring diagram for a 2001 pontiac sunfire steering collum
There are no wiring diagrams for the "steering column". Wiring diagrams show the wiring for circuits, not the parts of the car that the circuits just happen to be fastened to. For instance, if you are having trouble with your horn, or if you are having problems with your turn signals, you would look up the wiring diagram for the horn, or the diagram for the turn signals, not the wiring diagram for the steering column.
Nov 13, 2011 | 2001 Pontiac Sunfire
NO NETWORK TOWERS SEEN AND IT SHOWING AS SEARCHING.....IN MY MOBILE THAT IS IN SAMGUNG L700
Change the SIM , if possible try on another phone to see the signal strength in your area. If there is no issue the network detection circuit is faulty. the signal receiver or trans-miter can be faulty or the mother board. take estimate to confirm.
Jun 14, 2011 | Cell Phones
Pa jumper pin no of nokia2626
Nokia 2626 Signal No Network repairing solution.Nokia 2626 Signal No Network Mobile Repair diagram pictures Service Tips and Tricks.Make Jumpers as shown in diagram or replace the shown components .
How to short Nokia 2626 PA.jumper Pa nokia 2626. here is a diagram that is showing how to jumper and short P.A of nokia 2626. it is used to check that mobile is getting signals or not. if signals are to low with jumper change the P.A
Jan 21, 2011 | Nokia 2626 Mobile Phone
Nokia N95 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
