Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
I HAVE THE 3200 . ABSOLUTE LOAD OF **** AND A COMPLETE WASTE OF MONEY. SOMETIMES LETS YOU MAKE A CALL SOME TIMES NOT SOMETIMES CUTS OUT PART WAY THROUGH. WHAT A DISAPPOINTMENT. ANY IDEAS.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Complicated without diagnose to get a solution.
But first, you will have to inform about the mobile you have, software version if possible and the software version of the kit.
We never know if there is a bad interaction between products, so if you can have like a doctor a crossing test between the head (mobile) the body (kit) and the legs (the vehicle).
With the combination it could be possible for me to describe possible troubles.
Check if you have the message goodbye on the display when you switch off the ignition key. If not, that could be a part of the aleatory trouble you have.
But you can also using a specific menu you have on the car kit into settings -> pair with phone and then select the menu without synchronization that may inform about the stability of both products.
Try a crossing test with an other phone to ensure that the trouble is coming from the kit.
Inform me to be able to make a diagnose.
Posted on Jan 05, 2011
MY TOYOTA D4 engine , when moves ,it shakes like something is wrong in the engine, sometimes cant off engine even if the engine is switched off, what is wrong?
Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online at www.reliable-store.com and get complete guide on
whether to repair or not, service it, and how to repair etc
Mar 13, 2018 | Toyota Cars & Trucks
2001 Toyota Highlander won't shift into overdrive after driving a few miles, stop and shut off then will shift fine until coming to a complete stop. When you start off again will not shift out.
Get this manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
try reliable-store com. they also have live chat to help you.
Also try manualslife.com but no live chat there
Feb 05, 2018 | Toyota Cars & Trucks
I got a 2005 chevy equinox fog lights stay on at all times.even on high beam.change switch,did'nt help.unplug fog lights switch works great.had to take relay out because it buzz at all times....thanks
2005 equinox
Jan 31, 2018 | Cars & Trucks
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
My 2006 4 cyl 2.8l standard chevrolet colorado revs up when in nuetral or when the clutch is pushed in (when its not engaged in gear) also it shows no temperature on the temperature guage it also doesn't...
2006 colorado
Feb 01, 2018 | 2006 Chevrolet Colorado
Power problem with 3250- not sure if it is the adapter or the socket...battery light comes on but weak and sporadic, don't want to waste money on new adapter if problem is in unit- thanks-
The power adapter has only one voltage. Very easy to check. Anyone with a voltage tester can check it for you. The voltage should be listed on the adapter.
Nov 27, 2009 | Averatec 3200 Notebook
Maytag washer not draining
then notify BEST BUY fixya does not do any mechanical work .
Nov 16, 2017 | Maytag HAV2460AW Top Load Washer
Car CD player will not load CD
manual online at www.reliable-store.com and get complete guide on whether to repair or not, service it, and how to repair etc
Mar 07, 2018 | 2001 Ford Escape
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
46 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
