Question about Panasonic Lumix DMC-TZ1 Digital Camera
Hi i am unable to connect the camera through USB port to the computer. in camera it display as PC but not access
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jul 02, 2011
Unable to access photos on computer using usb cable.I plug in usb,select computer the screen freezes with Access showing.Can you help?
Hi
You don't mention models or OSs details so I will have to be general. Some possibilities:
Firstly. Make sure that you wait a reasonable time after plugging the camera into USB, before you try and do anything on the computer. It could be that you are interrupting the connection procedures.
Secondly. Can you remove the memory card from the camera and put it into a card reader connected to the computer. This is normally the simplest and quickest method.
Thirdly. Is all the software that came with the camera still installed properly ? Re-installing this software may solve your problem.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 06, 2014 | Cameras
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
My new t21 display said "unable to access card" my
If you are using the camera to download pictures to the computer you should be able to set around this problem by purchasing a card reader. These plug into the USB port and the camera SD card plugs into the reader, the computer then loos at the SD card as an external Hard Drive. Create a new folder in ? "My Documents" transfer the files from the camera memory card (copy past) into the new folder and you have your pictures not on the computer hard drive.
Do a "safely remove" "eject" or what ever language you computer uses to shut off the connection and disconnect the memory card from the reader.
Format the memory card in the camera always format the memory card after downloading pictures to the computer and always make sure it has completed the download and you have turned off the feed.
Failing this your do two things corrupt the card and possibly the camera software.
Okay another thing that the SD card have is a lock I'm giving you a diagram to see and make sure the card is in the write position.
Diagram
You should be good to go
Jan 20, 2011 | Canon EOS Rebel XSi Digital Camera
Sony cyber shot w350 i can down load still photos no problem but i am unable to transfer video to a computer. i have configured the usb connection from auto to mass storage as sudjested in the manual but...
Hi
Sorry to hear of the problem with your Sony Cyber-shot DSC-W350 camera.
You don't actually say how you are trying to take the videos off the camera - is it via the included Sony software or are you trying to access the data via Windows Explorer when the USB cable is attached?
It could be a problem with the USB cable or port - possibly static build up (switch the computer off and unplug it from the mains for 30 minutes) or try another USB port or computer.
You need to try and narrow down the fault further.
Hope this helps a little
David
Dec 29, 2010 | Sony Cybershot DSCW350 Digital Camera
I keep getting: The software is unable to find Olympus digital camera connected to a USD port on your computer . Would you like to search again? I have connected the cameriavia USB, the camera screen shows...
Hi if cant find your software for your camera,
may be you can try to get a external card reader
that you connect to the usb and it will be recognized
automatically,.
hope that will help you
Apr 11, 2010 | Olympus Stylus 7010 Digital Camera
I am unable to download my pics onto my computer. As soon as I plug in cord going into the "AV/Out Digital" spot on the camera, the camera turns off. It will not stay on. I checked the battery and it is...
All cameras do this. As soon as you plug in the cord, the display will turn black. It is completely normal.
If the pictures aren't showing up on computer, make sure the latest drivers are downloaded for your camera. Also you can use, picture transfer or kodak easy share program to download.
Another way is to go to 'my computer" than either f: or g: drive should have your camera on it. You can access pictures here and drag n drop into another file.
Jun 15, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Have windows vista on new computer, no longer have CD ROm for camera. I am unable to access the software when I connect it through USB port???
The camera should be detected as a drive when the camera is connected via USB. Does it? You should be able to connect and copy your photos straight out like a USB drive.
Apr 26, 2009 | Pentax Optio 330RS Digital Camera
Olympus E510
Make sure the camera is on and STORAGE is selected on the camera screen when connected to the computer. You will need to have STORAGE highlighted and select OK on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Aug 01, 2008 | Olympus Cameras
Cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Feb 05, 2008 | Fuji FinePix S700 Digital Camera
Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Aug 19, 2007 | Pentax Optio S4i Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
