Question about Lionel Little Lines Train Play Set W/remote Control
We have changed the batteries 3 times in both controller and engine. We have sound and light on engines but no movement of engine. What can we do to troubleshoot? 71-1163-250 manf. China 7/09
I bought this set for my grandson and had no problem. The booklet says to make sure all screws on the battery compartments are tight, and they are fresh batteries installed properly. Then i saw this post on another website:
http://screamingreviews.com/lionel-little-lines-freight-set-review-this-toy-train-christmas-present-was-a-big-hit-with-the-kids/
"The plastic train was another matter. I went through several sets of batteries trying to get the thing to run. No matter what I did it wouldn't run right. It didn't do anything. Then I took it apart and found that there was a sticker that indicated which way the batteries were supposed to go in and the sticker had somehow become lodged covering the battery contact on the inside. This is why nothing worked. Once I removed that sticker and replaced the batteries everything worked perfectly."
Look carefully at all contact surfaces to see if anything plast ic blocking the metal.
If all else fails and you can't return it, I would be interested in buying more track for my grandson! kohls@juno.com
Posted on Jan 01, 2011
Problems with car engine light coming on and off,after 2or 3 days i need to add another battery
? is that a check engine light or a wrench light sound like the bearing is gone in the alternator ,and that will kill your battery when engine is off change alternator should fit the battery problem ,go to autozone and have that check engine light code
it is a free check
Feb 17, 2015 | 2001 Lincoln LS
Bmw 3 series electrical faults
Hi sounds like the same problem I had crankshaft sensor my battery light came on and the engine would cut out sometimes would start straight away other times took 5mins to start again.
But would get a garage to check fault codes costs about 40pound but could save you 100's as it may be a faulty alternator/battery.
Jun 16, 2014 | 2007 BMW 3 Series 328i
Ford E 150 idols very low installs constantly
I'm sure the engine light must be on, If it has an IAC code it is probably the culprit.
If you have a lean code.... Have you .... ever ... changed the air filter?
May 28, 2014 | Cars & Trucks
Turns but will not start
Check to see if the Check Engine Light comes on when you first turn the key on (without cranking the engine). If not, there may be a power issue (fuse). Make sure that you have spark and fuel injector pulses. There may be a chance that the timing belt jumped or broken. Sometimes you can tell by the sound of the engine; rather than the usual sound, it makes when cranking, you may hear the engine cranking unevenly or faster than normal. Sometimes you can tell if the belt is broken by removing the oil fill cap and looking for valve train movement. Otherwise, an engine compression test will sometimes help to diagnose this. Sometimes the timing belt cover has to be removed to check for this condition.
Aug 02, 2013 | 2001 Hyundai Elantra
Error codes for 1991 dodge spirit
Turn the key to run then off, back to run, then off, then to run and leave it on. The check engine light will be on and will then go off and then on again according to the codes the engine controler happens to have in it. If the check engine light was on when you stopped the car, then there is at least one code in the controler. The light will blink the codes like this.
Cycle the key three times and leave on on the third time. light on for about 3-4 seconds then goes out for about 2 seconds and then blinks one time and goes out for 3 seconds this is for the no.1. Then the light blinks 3 times and goes out for about 3-4 seconds. You have the code 13. You could have a whole string of codes in the controler memory. It could be something like this. key cycled 3 times, light on for 3-4 seconds, then blinks 1 time, pause, 3 times, longer pause, 2 times ,pause 4 times, longer pause, then 5 times, pause 5 times the goes out.
This is code ; 13,24, 55. code 55 isn't really a code. It just tells you it's the end of any codes the controller has.
If you disconnect the battery and hook it back, you will have code 13 which simply mean 'battery disconnect'. It will errace it's self after several starts if it's not disconnected again. If you cycle the key and you get 55, this means there are no codes recorded at this time.
You will allways get 55 when checking for codes wheather there are fault codes or not. The light on for a few second before the codes start flashing is only a bulb check. Some codes like 13 will not turn the check engine on, but but will leave a code for diagnostic purposes only. If you have the check engine light on and accellerate and the light begains to blink, then the controller is telling you that you have an engine miss and are running the chance of burning out you're catalatic converter if you continue driving. Sometimes its advised to disconnect the battery after you have recorded the codes.
This will erase all codes that are present but were generated by conditions that aren't pertanent to the present condition. and then the codes that come back are the real ones to address.
This link: http://minimopar.knizefamily.net/fault/index.html
Contains the entire list of Chrysler Engine Error Codes.
Mar 03, 2011 | 1991 Dodge Spirit
My 1995 Mercedes 420E bucks like if it is running out of gas!! but the engine never stop running. I have put it in shop 3 time now!!! I get the same answer very time if the check engine light don't come on...
Sounds as if the engine control module has gone bad. Here's the funny part if the engine control module is faulty it will never know its faulty so it may never turn on the check engine light. The throttle actuator and the air flow meter can also cause driveability problems with the M119 engine. You should be able to pull blink codes from the 8 or 12 pin connector next to the battery. pull the little cover off the connector that sits on the firewall. With the key in position 2 and the engine not running push the little button in for 3 seconds and watch and count how many times it flashes. If it flashes only once then that means no faults. If it flashes more than once then count the blinks and repeat holding for 3 seconds to see if there's more then one codes. This is checking the codes of the DM (diagnostic module) it should have a code if the engine control module is faulty. All this is assuming that all the initial step have been taken like checking distributor cap,rotor,plugs,wires and vacuum leaks.
Oct 11, 2010 | 1995 Mercedes-Benz E-Class
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
Speedometer, tack, fuel gauge, temp gauge have erattic behavior
With Ign. off what is your batt.voltage reading than take neg. cable off and take another reading 5 min. later. It sounds like a intermitten short, try to isolate voltage drop when acting up. Gauge circuit would be a good start. Schematic would be helpful.
Aug 12, 2009 | 2000 Ford Windstar
My 1998 BMW 328i SERIES has a brand new battery but when I go to work and come back at the end of day, it seems to have a hard time cranking up. Can the radio or the air conditioning being on can take...
Firstly nice car.
It sounds like the alternator could be giving you hassle and the battery is not charging as you drive it. Two easy ways to check this 1. drive your car close to a wall at night and rev the engine with the lights on, if the lights dim then the alternator is nackered. 2. If you have access to a voltmeter check the voltage on the battery with the engine off, then turn on the engine and get some one to rev it. If the alternators working then the should only be slight movement in the voltage if not it will drain heavily (5-10 volts)
To reset the check control light turn the key in the ignition to as far as all the lights in the dash come on (dont start it) leave it in this position for about 2 mins (the car runs its own diagnostic check) then turn it off take out the key and put it back to the dash lights on position again.
Hope this helps.
Mar 25, 2009 | 1999 BMW 328 Series
Lionel Little Lines Train Play Set W/remote Control Logo
254 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
