Question about Sport & Outdoor - Others
Dear , I have Strength master MI310X tread mill , after 5-10 of start its speed automatically increases & it trips with E1 error , can you please help to resolve this problem , it is occurring since the day one Thanks
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
  • 14 Answers
SOURCE: It gives a E1 Error
replace lower electronics board and motor controller if applicable.
Posted on Apr 09, 2011
ercupa190
  • 12223 Answers
SOURCE: The control panel doesnt function other than to increase and decrease the speed. The tread mill is a Reebok 8700 ES
adjust the reed switch see the diagram attached, clean, and tight the connector very well.
after your fix it RUN the software calibration for easy diagnose and troubleshooting .
see your instructio manual for this if you do not have go www. fitness.manualsonline. com or www. iconservice. com
sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: my york pacer 2500 will not increase its speed
please RUN the software calibration for easy diagnose, troubleshooting and fix it. test the speed sensor, see the diagram attached. clean it,and tight the connector very well.God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003976 StartFragment:0000000468 EndFragment:0000003959
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Posted on Mar 27, 2013
ercupa190
  • 12223 Answers
SOURCE: Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
Posted on Mar 29, 2013
Triumph 400T belt won't turn, and get E1 error message
You have to check the Speed sensor of the tread. IF the speed senor is faulty this problem can occur. Normally in all treadmills E1 denotes the speed sensor error.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Triumph Academy Sports 400T Treadmill
MY AF 843M AEROFIT TREAD MILL IS SHOWING AN ERROR E1 AND SOMETIMES E6. KINDLY GIVE US THE SOLUTION
You have to check the Speed sensor and its position.Normally you will find the speed sensor near motor pulley. In almost all treadmills E1 Error is related to speed sensor.
Jan 04, 2014 | Exercise & Fitness
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
Fix error 2 treadmill
this is a probably a faulty sensor speed see the diagram attached. However depend of your mark , model, can be e1 ,tight the connector very well, and clean it. Test the s.speed for open or faulty.
Oct 19, 2013 | Exercise & Fitness
Turn tread mill on. counts 3 seconds and the belt does not move. the console goes blank after 8 seconds then e1 flashes.
follow this steps and fix it. See the diagram attached. God bless you
ERR 1 - Motor Movement
the signal is not reaching the display.6698c5a0-3470-4d34-bd47-9422824cf011.gif
Of course you must lube the deck belt. see the video attached.
Sep 20, 2013 | Exercise & Fitness
Treadmill E1 Error
God bless you
Mar 29, 2013 | Exercise & Fitness
Sportart 1050 series 1000 ,power on ready to go push start the Tred mill starts then stops emmediately showing error 1 ?
This may be helpful: http://www.treadmillsrepair.co.uk/2014/04/speed-sensor-for-treadmill-error-e1.html
Feb 18, 2012 | Sportsart Exercise & Fitness
It gives a E1 Error Code and It is an Kikos Ts-73021 Tread Mill
Apr 08, 2011 | Exercise & Fitness
Error codes
error 1 is many times a speed sensor error. Make sure the speed sensor is in place, working and sending signal to the motor control board.
Jan 03, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
61 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
