Acer 5532 will not boot,no hd light,usb does not work,acer would not help now out of warranty thanks acer !!!
  • 12 more comments
  • cold2 Dec 31, 2010
    power light comes on but i have a black screen
  • cold2 Jan 01, 2011
    have tried does not work
    light stays solid
    no sounds
    yes nothing connected
    fan starts for a second then turns off
    same result no change
    no spark
    how does the cd/dvd come out
    everything removed no change
    yes i have got the cd/dvd drive out i think all cards are out no change on boot up
    i have tried no change i have seen poeple flashing the bios is that a good idea,also is this computer worth putting a motherboard in
    specs are the same except i have a 160 gb hard drive it is about 1yr old
    thanks for your help i will never buy acer again!!!
  • 2,567 Answers
If you wiggle the power cord at the end plugged into the laptop, does the power LED blink, or the light stays solid?
Please answer this question before we could proceed with the diagnosis. I will pick up your answer & proceed with the diagnosis of the case with you.
Posted on Jan 01, 2011
  • 9 more comments
  • Mohamed Omran Jan 01, 2011
    Ok. Next question is: When you power up the laptop, do you hear any beep sounds?
    Ok. When you power up the laptop, did you make sure that all external peripherals (e.g. USB memory stick, external hard drive, printer, web cam, ...etc) are disconnected from the laptop?
    Ok. You mentioned that you don't see any HD light when you power up the laptop. The question is: Do you hear the sound of either the fan or the hard drive? I assume not, but would like to make sure before we move to next step.
    Ok. Then to the next step: Did you try to boot up the laptop without the battery? If not, I suggest that you uninstall the battery, & try to power up the laptop using the power from the AC adapter only. Then please let me know what happens when you do this test.
    Ok. With the battery removed, unplug the power cord from the laptop's power receptacle, then plug it again & watch while you are doing this if there is any spark at the power receptacle when you plug the power cord in? Listen & observe carefully if there is a spark at this moment.
    Ok. Now we will need to disconnect internal drives (both the hard drive & CD/DVD drive) one at a time, then try to power up the laptop after removing each of them. If the problem still persists, then we will need to do the same with installed cards (the WiFi card, the modem card, even the memory modules if you have more than one). Try powering up the laptop each time a part is removed.
    Please let me know of the outcome of this so that I could provide further recommendations if needed.
    On the bottom side of the laptop's case, there should be one or two screws that needs to be unscrewed before you can snap the CD/DVD drive out of the case. These screws are usually about 15 cm from the rim of the CD/DVD drive.
    Ok. May be this model has a different way to hold the CD/DVD drive in place. I need to double-check.
    Can you skip this step & continue with the diagnosis, keeping the CD/DVD drive as the last part to remove from the system?
    And the memory module(s). Have you tested the laptop with one memory module at a time? If you have only one module, have you tried to power up the laptop with this module removed & noticed if you get any beeps or if this changed the behavior of the laptop when it is powered up?
    If none of these helped resolve the problem, then we are left with only one possibility: a faulty motherboard.
    As the motherboard is already faulty, we won't lose anything if the flashing of the BIOS did not help.
    As for whether it is worth replacing the motherboard or not, I need to know how old is this laptop? And what is its specs?
    Does its specs match these: http://www.newtechnology.co.in/acer-aspi...
    I don't think this laptop is worth replacing the motherboard. I checked on ebay.com & found this motherboard:
    http://cgi.ebay.com/Acer-Aspire-5532-553...
    As you see, it is a used one. Yet, it is expensive (US$ 239). I think that your laptop after 1 year of use is worth almost the same amount of money if it is working.
    Based upon this, I think you might better start with a new system. I would suggest a higher quality system if you can afford the price. Don't accept less than 2 years of warranty.
    And as for your old laptop, may be you can sell it on e-bay.com for spare parts.
    Genius:
  • 1,098 Answers
Hi.
Does it even power up? Do you see a blue screen?
Rry tapping "F8" key at boot-up then select the option "repair"
Posted on Dec 31, 2010
  • Ivy  Cada
    Ivy Cada Jan 01, 2011
    Try to connect an external monitor. That way, we can eliminate monitor screen problem first.
Why won't my once it acer 5532 won't boot once it powered on
it isnt reading your harddrive......remove your harddrive for a few seconds then plug it back in ...if it doesnt work then you need a new harddrive
Jun 29, 2014 | Acer Aspire 5532 Window 7 1.6ghz Amd...
Usb plugs on acer aspire 5532 not working,can i fix
USB drivers out of date. Go to www.cnet.com and get the download for Drivermax (there's a free version) and install it on your computer. Then, run the program and it will tell you which drivers, on your computer, need updating. Drivermax gives you two 'freebie' driver updates per day, or you can pay to upgrade the app and get them downloaded all at once.
Feb 16, 2013 | Acer Palmrest for Aspire 5332, 5516, 5517,...
Replace the usb ports on an acer aspire 5532 laptop
You need to dismantle the laptop completely to get to the motherboard so you can replace the USB socket.
Oct 14, 2012 | Acer Aspire 5532-5535
Acer aspire 5532 is in loop wont boot error windows failed to start a recent hardware to software change might be the cause
Because of the power interuption the recovery partition has been corrupted, the hard drive will need to be formatted to use the recovery discs. Go to www.acer.com contact customer support and the technical department for additional help, they have one of the best support programs available.
Jun 28, 2012 | Acer Aspire 5532 Window 7 1.6ghz Amd...
Acer Aspire 5532
webcam has own microphone which use USB like camera. Windows has own port for microphone.
go to software options which you are using with camera and change recording device to different one " it should be named like "USB mic" or something like that.
i would check to software included to camera too
Mar 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
241 people viewed this question
David Payne
David Payne
