Question about Tascam DP01 All-In-One Recording Package Microphone
Hello : I have a Tascam portastudio_dp_1fx. Anyone knows how to reset this message: Err: 12 Please PWR OFF
    President:
  • 1,961 Answers
Hi!
This error will only dis appear when you replace the ac power adapter that comes with it.
Or you better check if the output voltage and the amperes are not dropping.
Your power adapter should out with 12 volts and 2.5 amps. Less of this value means its dropping and its not stable..
You can use a multitester to check if the output voltage and amperes did not meet the requirements.
Hope it helps!
Alpug
Posted on Jan 01, 2011
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Manual required for tascam portastudio 03
If you have the model DP-03 then the manual download can be found at:
http://tascam.com/product/dp-03/downloads/
If that is not your model, the other models manuals can be found at:
http://tascam.com/support/downloads/
Jun 02, 2011 | Tascam Audio Players & Recorders
Tascam DP-02
I had the same message on my DP02 error 12 please power down. I went to an electronics store and asked a computer technician and he said it probably isn't getting proper power to start up .We looked at the manual specifications for power and found it needed a power adaptor which has an output of 12 volts and 2.5 amps which is 2500ma. Once I put that adaptor on it everything powered up and it works great.Look for an adaptor that says output 12v 2500ma and it should work fine.
Nov 15, 2008 | Tascam DP01 All-In-One Recording Package...
No HDD:20 Please PWR OFF
It means the harddrive has crashed. I have the same model. It is a manufacturer flaw. You can try saving your recordings on external devices or contacting Tascam directly.
Oct 05, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam Portastudio DP-1FX/CD When I turn it on I get this message. Err: 12 Please PWR OFF
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Cheers
BD
Apr 22, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
113 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
