Question about KitchenAid KHWS01PMT Front Load Washer
The panel light is on at control lock is this an easy fix
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Hold the control lock button down 5 seconds and it should unlock.
Posted on Dec 31, 2010
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
1.my cruise control stopped working,how do I figure out whats wrong.2.When I enter my car the interior lights start flickering and the locks keep keep jumping around like thereunlocking and locking then it...
this sounds like it could be a ground wire problem and not a fuse problem.it will not neccesarily be an easy fix.all ground wires need to be checked.this coincides with the lights and lock problem.this is just a starting place but an important starting point.
Nov 01, 2013 | 1994 Oldsmobile Cutlass Ciera
My rear doors will not lock by the front control locking system
Do they lock with the other controls? If so, the the problem is that control switch has gone bad. Its an easy fix, you can get the part at any auto parts store. Pop the cover loose on the control panel where the switch is, and remove the switch (some are screwed in, and some just pop in). Unplug it. Bring it to the store and let them match it. plug in the new switch, pop it back in, snap the cover on. fixed. Hope this helps
Dec 29, 2010 | 2003 Cadillac Escalade Esv
Control off is on, how can I fix it?
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Driver side power window/lock control buttons on arm rest the backlight is burned out, is that easy to fix?
yes it is VERY
take the control panel off and you will see the connector for the light...turn the light socket to remove it...pull the bulb out...replace buld...reverse to put back together...your done
Feb 04, 2010 | 1989 Buick Regal
Me washing machine has a light that says control
You may have inadvertently locked the control panel. The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove the front control panel?
remove the 3 screws at the rear top to remove the top cover. you now have access to back of control panel. tou should see some plastic lugs sticking out through metal clips. you will have to force the lugs through the clips with a flat blade screw driver. be careful it is easy to brake them
Feb 13, 2008 | Asko W6021 Front Load Washer
Whirlpool Front Load Duet Dryer
Elsewhere on this forum a fix was given that is rather easy. Someone in your home has activated the child safety switch. On the lower right hand side of the control panel, hold the bottom button in for 3 seconds until the light goes out.(safety control lock switch)
Nov 11, 2007 | Dryers
Control panel
Probable microprocessor IC lock-up.Usually found on signal
PCB==expensive to change out.Sorry--no easy fix on this one.
Aug 01, 2007 | Akai PT5492S 54" Rear Projection...
KitchenAid KHWS01PMT Front Load Washer Logo
19 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
