Question about Vornado (CR1-0073-06) Fan
Old Vornado fan model FAI 0013 has a broken plastic split ring clamp that holds the front blade screen on to the back screen. Need to find a replacement, because otherwise the fan runs great.
    Sergeant:
    Champion:
  • 342 Answers
Try some black duck tape that might help until you can find a replacement parts
Posted on Jan 01, 2011
Vornado Swan parts
Call vornado 1(800)234-0604 to order part. About $25- shipped.
Aug 25, 2012 | Vornado Silver Swan Table Fan
Tip
VORNADO FAN BROKEN BLADE DONT REPLACE!!!!!
My dog knocked off my vornado which then broke a blade off my favorite fan. I was going to use epoxy to try to get the blade to stick back on. This would not work. The fan spins to fast to use glue. I sat and thought about it for awhile and came up with a solution rather then spending 39.99. I used epoxy to get the blade where it should be and let it dry..... then took a hot nail and poked a hole through each blade close to the center of the shaft.... and then took a zip tie and connected each zip tie to each other forming a ring around the shaft. This works very good and if you need to balance out the fan just place a small zip tie on the center and clip off close to the lock. Now you can use the LOCK as a balance for the fan. GOOD LUCK
on Aug 28, 2008 | Vornado Circulating Fan
Vornado fan Model CR1-0023 , Type 750 I bought this fan used 3 days ago. Seemed to work fine but not as powerfully as another new Vornado shop fan I have. Today the fan blades stopped turning. I can...
I have had the same model for almost ten years, and have had to lubricate it twice - both times when the fan stopped rotating. It's obvious that Vornado never intended the bearings to be serviced, but if you're patient, it can be done. You must remove the front louver section (press the three clips inward gently). Then firmly pull the fan toward the front, off the shaft. Then remove the four nuts on the front of the motor housing - you'll note that the bolts appear to be free-floating, but that allows re-assembly after the bearings are lubricated. When the nuts are removed, firmly pull the front of the motor housing toward you. This may require a firm pull or GENTLE prying, as the rear bearing sometimes doesn't want to let go. When you have the front portion of the housing and shaft out, hold the housing and pull the shaft out of the front bearing. Again, this may require a steady firm pull straight back. When the rotor & shaft are free, you'll need some very fine emery paper to remove the varnish that's built up on the shaft (it's unmistakable where to clean the shaft.) And I never attempt to do anything with the front and rear bearing themselves - too much work, and cleaning the shaft does the job for me. Then clean everything up carefully and lubricate the shaft where it enters the bearings (and maybe a drop in the rear bearing itself.) I use a very fine machine oil that I bought at Sears, but I think any good oil would work. Then, it's re-assembly time - shaft into front bearing, shaft into rear bearing as the motor housing is put back together (lining up the bolts), four nuts on the bolts & tighten (firmly, no gorilla), press fan back on shaft (don't force it too far on - it'll stop when it's in the right place), plug in and check, re-attach front louver (just press - the clips will snap easily into place.)
Jul 27, 2011 | Vornado CR10023-06 Air Circulator Fan
I have an old Vornado floor fan (sits on pole which curls around to form base) and cannot figure out how to open it to clean. I've read through all the other questions, which indicate clips or screws....
Hello Johnsbrandt - I had the exact problem. As you note, the four slits are they key. They are tabs that hold the outer ring in place. Press them so that they no longer catch on the back ring, and you should be able to slide the outer ring right off. The outer ring on mine was somehow catching on the blade, plus it was dirty, so it was good to get this off. Hope this helps! Lance
May 11, 2011 | Vornado Circulating Fan
I have a Vornado floor f an, the blades iof which are coated with heavy dust. How do I remove the front protective screen to clean the blades.
On the model I have, the front grill just pulls off from the front; there are some tabs that you might need to release by pushing with a small screwdriver from the rear. After cleaning, just align the tabs and push it back in until they click back in and latch.
Oct 24, 2010 | Vornado Circulating Fan
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Vornado 210B floor
You can turn the unit around backwards and find three integrated clips holding the front cover on.I use a flathead screwdriver to disengage the clips and the front cover just slips out.
I use a vacuum and windes on thr blade surface.
saw your question and thought I'd chime in.
Good Luck!
Gregg
Sep 23, 2008 | Vornado 210B Floor / Box Fan
Motor problem
hi,
I wrote to a person earlier about oiling one, now Im thinking she may be having the same problem you have, I will paste that info at the bottom, but sounds like your fan blade assembly has come loose and/or worked its way back down to the motor, study the fan blade assembly and look for an allen bolt or ring holding the assembly to the shaft, remove the ring or loosen the allen bolt , adjust the fan blade assembly so it doesent bind, oil the motor with regular 10w40 motor oil and dust the fan, these are good little fans and that company has been making those since the40's, also sending user guide link.
http://www.vornado.com/manuals/allcirc.pdf
J
Aug 04, 2008 | Vornado Circulating Fan
Vornado (CR1-0073-06) Fan Logo
867 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
