Question about Gold Medal 2005 Deluxe Whiz Bang Popcorn Maker
The Kettle get plenty hot but does not pop Half the Kernels.
5 Suggested Answers
SOURCE: Galaxy popper g12 unpopped kernels
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
Posted on Jan 13, 2009
  • 30 Answers
SOURCE: popcorn maker jams up - burns kernels
Please call Nostalgia electrics at 1-920-347-9122 so we can help you get the piece you need.
Posted on Oct 30, 2009
rickead1
  • 1998 Answers
SOURCE: Gold Medal Products Whiz Bang
Have you checked to assure that the warmer switch and the kettle heat switch are both functioning properly? Also the timer on the bucket seasoning pump control box determines the length of time the heat element of the bucket pump is at HIGH HEAT i also suggest you take a look at this pdf of the manual of your machine under the troubleshooting guide area if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
http://lib.store.yahoo.net/lib/yhst-81132447584496/47699.pdf
Posted on Dec 21, 2010
SOURCE: I have a Star model 89, manufactured in about
Make sure your agitator arms are properly functioning. If the corn is not being properly stirred, it will not pop. Also, make sure you are using the correct type of popcorn oil.
Posted on Apr 22, 2011
Why is it taking a long time to start popping, not popping completely, and leaving excess oil?
Sounds like the kettle isn't getting hot enough. The thermostat is usually at fault in this situation which can be determined by checking the amp draw on the kettle. the common complaint is the kette is too hot and burning but what really is going on is it's not hot enough so the seed won't pop. Because of the heat that is there it will loose it's moisture, dry out and burn instead. You will end up with lots of old maids . Really stale corn seed will act the same way because all the moisture in it is gone and thats what is needed to pop it.
Feb 14, 2016 | Gold Medal 2121 Econo Popcorn Maker
Our store owns a gold medal #2656 popcorn popper but now it will not pop but few kernels. is it not getting hot enough or is it something else?
no you shouldn't have to do that. you are correct about the heat. what happens is it doesnt get hot enough for the moisture in the seed to expand to pop it, but its hot enough to dry it out so it cant pop. so it burns instead and you end up with a bunch of old maids. the thermostat is the first place to check.
Feb 05, 2016 | Gold Medal Products Gold Medal 2656 6 oz....
Gold medal kettle heats up but not enough to pop corn
do you put a half a teaspoon of oil in first before the corn kernels
other than that have the unit checked by an electrical appliance shop for problem thermostat or heating element
Nov 15, 2015 | Gold Medal Kitchen Appliances - Others
Why is popcorn burning?
If you are sure the corn is not dried out, sounds to me like its not getting hot enough. It will just dry out the moisture in the seed and burn it if the kettle is not hot enough to make the moisture expand and pop the seed open.
Jul 21, 2015 | Kitchen Appliances - Others
Kernels wont pop compleatly
The kettle temp is not getting hot enough so your seeds dry out and have no moisture left to pop. Very stale corn seed will give you similar results.
Mar 10, 2014 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
May 06, 2013 | Elite Epm250 Popcorn Maker
ALL THE KERNELS ARE NOT POPPING
There are several possible culprits for your Kernel Caper.
1) You may need to add a little more oil to the kettle. Let it come to full heat--just as soon as the oil starts to smoke.
2) The corn you are using must be reasonable fresh and have sufficient moisture to pop the kernel. You can try putting 1 tsp/1 lb of corn in a ziploc bag or screw top bottle. Leave for 24 to 48 hrs to let the corn absorb the moisture.
3) Finally, due to the small size of the popping kettle some kernels will be thrown from the kettle from other kernels popping open.
This is a great little popper. You might have some luck decreasing the size of your batch--reduce your oil and corn by 1/4 each.
Good Luck
Sep 24, 2010 | Maximatic EPM450 Popcorn Maker
Ccp-509 popcorn kettle stop spinning when popcorn begins to pop. It won't pop out of the kettle.
Normally that is caused by too many kernels used. It pops too fast and jams up in the kettle. It could be a problem with the kettle though. Call 920-347-9122 for help with it.
Feb 13, 2010 | Nostalgia Electrics Helman Group CCP-509...
Jan 13, 2009 | Galaxy G18-AT Popcorn Maker
Gold Medal 2005 Deluxe Whiz Bang Popcorn Maker Logo
73 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
