Question about Dryers
Whirlpool crosley dryer cbe227v, the dryer will not start, you can here it hum but it wont actually start.
    President:
  • 1,194 Answers
If the dryer won't start then it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the motor that has gone bad as the hum sound comes from the motor & you will have to replace it to solve this issue.
Hope this will help....
Posted on Jan 01, 2011
My crosley elec dryer start switch is shorting why?
HUM MOISTER OR TINY BUGS INSIDE SHORTING IT? TEST IT WITH A METER
May 09, 2015 | Crosley Dryers
Drum wont turn
Either
- the belt has slipped off or snapped (the motor will whine high)
- the tension spring has broken
- the motor start capacitor has failed (it will hum heavily but not turn)
Nov 23, 2013 | Crosley 37001287 Dryer Belt Tension Pulley...
I have dryer lgr3624eq1 when you push the start button it makes aloud humming sound and wont start but if you wait 2 hour it will start but it will shut off before the full time
We're sorry to learn of your experience. We recommend service for a proper diagnosis. If further assistance is needed, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 17, 2018 | Whirlpool LGR3624JQ Gas Dryer
GAS DRYER WONT START
Most likely you have a bad motor or broken belt.
May 15, 2012 | Whirlpool WED5520SQ Gas Dryer
Whirlpool dryer. When pressing the start button the motor humms. It keeps humming until opened or unplugged. Does seem to generate heat though.
maybe a broken belt, here is a website that will assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 13, 2011 | Whirlpool LGR7648KQ Dryer
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
The dryer hums, but the drum wont turn?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2010 | Crosley CDE6000 Electric Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Crosley dryer
right the part that is faulty is a silver tube which is fastened to the motor take it of making sure you have done a diagram of the wiring replace it once replaced the dryer will work fine common fault on these dryers its just wear and tear m8
Nov 17, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
Top Dryers Experts
