Question about Coleman Heating & Cooling
We have had a coleman central air system for 5 yrs. It stopped blowing cold air into the house about a week ago. You can still here it running but no air is coming out. my husband replaced the fuses and over night it did the same thing so when my husband went to check out the unit outside he said that the line had ice on it. Is there a filter within the central air unit that needs replaced?
    Novelist:
    Champion:
  • 230 Answers
Ice is an indication that the refrigerant is not flashing off correctly in the evaporator coil. In most cases you can simply turn the unit off (until it completely thaws inside and out) and replace the filter. Make sure that all the vents in the house are open as well. If this does not work then you will need a technician to come out and check the refrigerant levels in the system. Ice can indicate that the refrigerant is low. I hope this helps.
Posted on Jul 08, 2008
I have a split system air conditioner that quit blowing cold air
either the compressor is not running or you have a leak and are low on freon. the outside fan running does not tell you the compressor is running.
Jun 18, 2014 | Coleman Outdoor Split System Air...
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
It runs cold briefly for about 4 to 5 minutes then
Check the compressor capacitor. It would have gone weak. Replace with the identical value and type.
May 26, 2010 | Coleman Mach III Air Conditioner
I have a coleman in my modular home, dosent blow hot air, everyth
Check the air filter and clean. If you can, raise the blower speed up to the next speed. Make sure all of the supply and return grills are open. Is the ductwork connected under the home and well insulated? Does the furnace ever stop or keep on running? If it does stop, you may have a bad thermostat.
Jan 03, 2010 | Coleman Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Have an amana central air duelfuel heat system.when aux heat[gas] heats the house and shuts off the fans still blow for 3 to 5 minutes with the last couple of minutes being cold air which cools the...
Change your heating delay to shut off sooner, you can find this in the installation manual. Also the Thermostat may have delay after heat as well. It is true there could be many variables, but it also sounds like the Heatpump is not charged properly, you will have to have a different tech come out and check that. No need to have the installer mess your system up any further. This solution will only correct the auxilary heat, your heat pump on the other hand will require expert skills.
Dec 05, 2008 | Amana Heating & Cooling
Coleman pac036h1021a service
I requested clarification on your problem and did not receive a response. I will assume that you are no longer in need of assistance from FixYa. If this is wrong, please repost your question.
Thank You
Jun 14, 2008 | Heating & Cooling
Heating & Cooling Logo
164 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
