Question about Brother Sewing Machines
My sewing machine squeaks loudly when I sew, and I need to know how to fix it.
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
dizzythevamp
  • 9 Answers
SOURCE: Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
Posted on Jan 06, 2009
Storma
SOURCE: Upper Thread Breaks!!!
Hi, here are some reasons why the thread is breaking :-)
  • Threading is not correct.
  • Thread has a knot in it.
  • Thread tension is too tight.
  • Needle is bent or blunt or has a sharp eye.
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Hope this helps.
    Posted on Jan 14, 2009
    • 1335 Answers
    SOURCE: A brother sewing machine LS-1217
    Go to
    http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus&type2=-1&flang=all&dlid=
    to download the manual and the quick reference guide.
    Please make sure to rate this solution. Thanks.
    Posted on May 26, 2009
    SOURCE: Husqvarna Viking Sewing Machine 6020 sews in reverse
    The grease in the reversing mechanism may have turned to 'glue' as in my Viking . I used a hair dryer to soften the grease , and then oiled it.
    Posted on Feb 10, 2010
    Machine squeaks when sewing
    Is it a mechanical machine (NOT computerized)?
    Do this ONLY if it is MECHANICAL. Remove the top lid and the freearm cover (if no free arm, then you'll have to tilt the machine so you can access the lower mechanism).
    Use ONLY fresh good quality sewing machine oil. While handrotating the handwheel, watch where metal parts move against other metal parts and apply 1-2 drops of oil. Do NOT oil plastic, rubber, or leather parts as oil will eventually destroy them.
    Be sure to oil the moving parts in the lower mechanism as well. Hopefully this will take care of the squeak and get your machine operating 100% again.
    Oct 23, 2015 | Sewing Machines
    My pfaff 1475 is starting to squeeke on the top of the machine
    PfaFF sewing machine squeak Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > sewing machine squeak
    I need a new mother board for Pfaff creative 1475 ... sewing machine by ... I am unable to disengage the sewing action on my Pfaff 1473CD to wind the bobbin.
    Sep 18, 2015 | PfaFF Sewing Machines
    My machine makes a terrible squeaking sound at the handwheel?when I wind the bobbin. What is squeaking and can I fix it myself?
    Depends on the make & model...
    Some older mechanical sewing machines need regular cleaning & oiling. Check your user manual.
    Apr 20, 2015 | Sewing Machines
    There is a loud squeaky noise when machine quilting a meandering stitch with a darning foot. The feed dogs are down, stitch width is 0, length stitch is 2.5. The machine does not squeak when using regular...
    Is the darning foot aftermarket or genuine darning foot for your particular model...If it is aftermarket, it may not be the correct length. What is you model?
    Jul 23, 2011 | Kenmore Sewing Machines
    I've borrowed a Silver 302 from my neighbour, and after a few hours use, it's started squeaking. Loudly. I don't know if this model needs oiling or not, and if not, what it may need doing to it - just...
    I'm not familar with this machine but will make some general suggestions. I did google it and found a 502 http://www.silverviscount.co.uk/shop/product_info.php?cPath=21&products_id=40 it looks like a economy front loading bobbin machine.
    If you manually turn the fly wheel to form the stitiches and listen carefully can you hear a popping as the needle enters the fabric? If yes, its a needle problem. All machines need a new needle for each sewing project, 4-6 hours sewing time, before they go blunt. Cchange the needle for a new one in the right size for what you are sewing (ballpoint for knits, sharp for wovens). Refer to www.sewing.about.com for good general info on machine maintenance, needle sizes and types and threading diagrams, its a wealth of information.
    If its not a needle issue then I would suggest that you open up the front flap, remove the bobbin holder, needle and pressure foot and clean out the race area with a small brush, then again manually turn the fly wheel and add a little drop of good quality machine oil to anywhere where you can see metal moving against metal and see if this quietens down the squeaking. Don't use 3-in-1 oil.
    You could also ask the neighbour for the manual and check out if it does have oiling points to try and eliminate this as a cause.
    Hope this helps a little.
    Mar 08, 2011 | Sewing Machines
    My Kenmore 12493 is making a loud squeaking noise. I have oiled the machine as per the manuals instructions...I can not figure out where the squeaking is coming from.
    Hi
    If you are good with machines you need to take off the bottom cover and oil all of the drive. The motor may all so need to be oiled.
    Good luck
    Dec 31, 2010 | Kenmore 15208 Mechanical Sewing Machine
    New sewing machine is squeaking
    YOu may have bent the needle. Put in a new needle and re-thread the whole machine. See if that works.
    Jun 28, 2010 | Husqvarna Viking 1
    Squealing noise Husquvarna 3310 sewing machine. Still sews ok but noise must be harming the machine. Anyone know what I can check?
    My Designer 1 started squeaking recently and, like you, I was concerned even though it sewed like usual. I emailed my tech. and he suggested either feed lifter mechanism or feed cam were the most likely causes - simple to repair but I would need to bring machine in for him to hear because there could be other reasons for the squeak. Well I did not have time to go then and there. Next day when I sewed, the squeak was gone!
    At the time it squeaked I was sewing through several fairly thick layers (making a pot holder) and sewing very slowly. The next day I sewed normal cloth at normal speed but no matter how slowly I sewed, I could not get it to squeak. I will get it checked eventually but as long as it is squeak-less I'm not going to be concerned.
    If yours squeaks all the time no matter what you are sewing then, yes, I think you should get it looked at. Be sure that nothing is rubbing against the body of the machine i.e. accessory tray and making the noise.
    Sep 28, 2009 | Husqvarna Viking 1
    Sewing Machines Logo
    77 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
