Question about Waterway Executive 48 Spa Pump 15hp 1spd 2" 34106101a ()
Looking for the propella that goes in side. - Waterway Executive 48 Spa Pump 15hp 1spd 2" 34106101a ()
    President:
  • Waterway Master
  • 1,378 Answers
Your old impeller should have a number on one side that starts with 3. It will read something like 3##-####. You can google that number for a number of online sources or if you would like a quote please email me using the contact feature found on our website at www.arrowpools.net.
John
Posted on Dec 31, 2010
Need coil to sparkplug wiring diagram
looking at your motor from the front wheel ......coil on left side bottom tower wire goes to first plug
on left, top tower wire goes to the last plug on right.
right side coil bottom tower wire goes to left side no# 2 or 2nd plug in . The right top tower wire
goes to 2nd plug from right, I hope that is what you were asking . I do not have picture but this
is simple enough. Ok Good luck
Nov 29, 2010 | 1994 kawasaki ZX-9R Ninja
Got the wires crossed, need to know what nu goes where,i dont know which wire goes where.
if its a v8,,the fire ring order is 1-8-4-3-6-5-7-2-,,drivers side,looking at side of motor from fender,,left is # 1-# 3-# 5-# 7,going left to right,,passenger side looking from fender at motor,,first plug right side #2 # 4 # 6 # 8,going right to felt,,hope it helped,,,
Feb 10, 2010 | 1998 GMC Yukon
Need to know which way to put the seal in 1998 harley softail front fork seals installation
In nearly ALL oil seal installations, the "lip" of the seal goes against the liquid flow. The lip faces the oil to prevent it from coming out. If you look at the seal, you will see a "solid side" and an "Open side". Looking from the open side into the seal, the inner diameter of the seal is the "lip". This lip goes in facing the oil or down into the fork leg. Solid side of the seal goes towards the lock ring.
Dec 26, 2009 | 2001 Harley Davidson FXST Softail Standard
I have a grundfos pump for my bore. It stopped working a few of months ago and we pulled it up, gave the propella (?) a spin. Tested it and it was working. Lowered it into the ground and it worked fine...
I'm not fimular with this pump but if you can spin the impeller (propellers are on airoplanes) and the motor will start and run it could be a start capicator. This stores elect. and gives the motor a bump in power to start.This will usually be found in or around the wireing box on the motor and should cost about 20.00- 30.00 dollers. You will need to find a service manuel for your pump and the motor that drives it. Good Luck with it, sorry that's all the help I have on that one..
Sep 29, 2009 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Monogram refrigerator can't keep temperature constant
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
My 1997 Chevy Lumina Runs Hot, replaced thermostat and radiator cap and hoses, but it still idels fast and runs hot. CAn you help here?
Good day
if you have replace the thermostat and rad cap, after the thermostat did you let the system burb it self. there might be an air pocket in the system. you can also check the strength of the coolant if its low it won't remove the heat. also check the front of your rad the fins make sure that it's not all plugged up with dirty, bugs etc. after you get the over heating under control then we can look at the high idling
hope this helps
Cheers
Jul 10, 2009 | 1997 Chevrolet Lumina
Thermostat replacement
The Flat side goes down and the Small Bell looking Side goes up.
Jan 26, 2009 | 1986 Dodge Cargo
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
REFRIGERATOR IS GOING FROM COLD TO WARM
Look in the freezer on the back wall if you see frost (looks like a thin layer of snow) you have a defrost problem . the cooling coils Behind the back freezer wall get cloged with frost and block the air flow to the ref side. The problem moast times is The defrost heater.
Jan 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hover Lites radio Controled Helicopter
They need to make repair parts for the helicopters for the price we pay the booklet dosn;t say where to get a part
Jan 06, 2008 | Optics
Waterway Executive 48 Spa Pump 15hp 1spd 2" 34106101a () Logo
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
