Question about Kwikset Locks & Locksmithing
How do I remove the interior assembly to repair?
  • 43,501 Answers
On the inside on the cover plate behind the handle there will be two screws or the cover plate it's self will spin off to expose the screws....
If the cover plate needs to be removed to get to the screws you may have a hard time getting the cover to spin and turn to remove it...get something sticky like a rubber pad and use it to turn the cover CCW...
Once you get into the screws...remove them and then the whole lock assembly will just pull apart....be caref ul to observe how it comes apart so you can get it back to gether again...
heatman101
Posted on Jan 02, 2011
How do i replace the heater core 1997 isuzu hombre
See me at website for images can only send one through this channel. www.autorepairhelp.us
Best Regards,
Master Tech Lee
HEATER BOX SHIELD
Heater Box Heat Shield
Remove or Disconnect
1. Fasteners that retain heat shield to heater box assembly.
Image [ Heater Box Heat Shield
Install or Connect
1.Fasteners that retain heat shield to heater box assembly.
Tighten
-Bolts Screws to 2.2 N.m (25 lb in).
HEATER ASSEMBLY
Image ' Heater Hoses
Image ' A/C Evaporator Tube Assembly
Image ' Evaporator Core
Image ' Evaporator Core Assembly
Image ' Heater Assembly
1.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2.Heater hoses. Refer to Heater Hoses.
3.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
4.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
5.Vacuum lines.
Important
-Clearly label vacuum line connections.
6.Heater assembly studs inside engine bay.
7.Blower motor resistor. Refer to Blower Motor Resistor.
8.Stud inside heater core housing.
-Stud is revealed by removing the blower motor resistor.
9.Rear case screws.
10.Heater assembly.
11.Seals.
Imagt
Imagt
Imagt
Imagt
Imagt
Heater Hoses
Evaporator Core
Heater Assembly
Install or Connect
1.Seals.
2.Heater assembly.
3.Rear case screws.
4.Stud inside heater core housing.
Tighten
-Stud to 1.9 N.m (17 lb in).
5.Blower motor resistor. Refer to Blower Motor Resistor.
Tighten
-Studs to 1.9 N.m (17 lb in).
7.Vacuum lines.
8.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
9.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
10.Heater hoses. Refer to Heater Hoses.
11.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
-Check the system for leaks.
Sep 06, 2014 | 1997 Isuzu Hombre
Heater cor is leaking how do I change it?
REMOVAL
  1. Disconnect the battery ground cable.
  2. Drain the radiator. Refer to: "Engine, Cooling and Exhaust : Cooling System : Service and Repair" See: Service and Repair
  3. Remove the instrument panel. Refer to: "Body and Frame : Interior Trim : Dash Board : Service and Repair" See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair
  1. Compress the holding tabs and disconnect the heater water hoses at the heater core.
  1. Remove the A/C plenum demister adapter.
  1. Remove the screw.
  2. Remove the A/C plenum demister adapter.
  1. Disconnect the vacuum line.
  1. Remove the heater core bracket.
  1. Remove the two screws.
  2. Remove the bracket.
8 Remove the plenum assembly top.
  1. Remove the 13 screws.
  2. Remove the plenum assembly top.
  1. Remove the blend door assembly from the case.
  1. Remove the heater core.
INSTALLATION
  1. To install, reverse the removal procedure.
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Dec 17, 2012 | 1997 Ford Expedition
Passat door 2006vw will not open from outside,but opens from inside
You need to get inside the door and reattach or replace the interior latch assembly that connects the handle to the latch release. This sounds like a lot of work but it really isn't and should take about 30 minutes to get the interior door panel off, repair the problem and get everything back together. The the door panel for any screws that maybe hidden under plastic caps and remove them. These are normally a #2 or #3 cross tip. Once those are removed use a flat screwdriver at the base of the door and pry up on the interior panel to separate the panel from the door, do this carefully and as you locate the push pins that hold the panel in place move the screwdriver close to the pin to do most of the prying. The closer you are to the pin the less damage is likely to happen to the door. These should pop out but are sometimes difficult. Once you have removed them the panel should lift off and you can access the latch mechanism and make repairs.
Feb 24, 2011 | 2006 Volkswagen Passat
Problem with dual zone heating only one side i check control thermost botton is ok
Sounds like the blend door actuator. It separates the driver and passenger side from getting air on the AZC system. Here are some instructions on replacing it:
The passenger side blend door actuator is used on all models equipped with Automatic Zone Control (AZC). This actuator is located on the front of the HVAC housing to the right of the floor panel transmission tunnel and cannot be removed from the passenger compartment without instrument panel or HVAC housing removal.
NOTE: This procedure is for AZC Systems (Passenger side only).
  1. Disconnect and isolate the battery negative cable.
  2. Remove the glove box door. See: Body and Frame\Interior Moulding / Trim
  3. Remove the lower I/P glove box door surround panel.
  4. Remove the dash assembly. See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Instrument Panel Assembly
  5. Remove the HVAC assembly. See: Housing Assembly HVAC\Service and Repair
  6. Unplug the wire harness connector from the blend door actuator.
  7. Remove the 2 screws that secure the blend door actuator to the HVAC housing.
  8. Remove the blend door actuator from the HVAC housing.
INSTALLATION - AZC (Passenger side only)
  1. In stall the blend door actuator on the HVAC housing and tighten the two mounting screws to 2.2 Nm (20 in. lbs.).
  2. Plug in the wire harness connector to the blend door actuator.
  3. In stall the HVAC unit into the vehicle. See: Housing Assembly HVAC\Service and Repair
  4. Install the instrument panel assembly into the vehicle. See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Instrument Panel Assembly
  5. Evacuate the HVAC system.
  6. Recharge the HVAC system.
  7. Connect and the battery negative cable.
Hope it helps! If you need more, just send me an email at familyguy77351 at yah I wil be glad to finish helping you with more detail.
Dec 12, 2010 | 2000 Jeep Grand Cherokee
How do I remove the drivers window controls on a 2004 Mercedes Benz C240
If you cannot see any bevelled edges to remove the master switch control, my suggestion would be the most common.... to remove all visible screws securing the interior panel to the door frame, e.g. behind door release handle, behind inside grip hande (as circled in photo), then slide & lift the interior door panel away slightly as one assembly, just enough to reveal any electrical wires.
Disconnect all wire looms from behind interior door panel...
Then, view switch assembly from behind the door panel, to determine best method to remove. Most modern switch assemblies are simply held in place by molded clips on the switch body, which need to be pushed out from behind.
Cheers,
"If this has helped you in any way, please rate this solution"
Jan 25, 2010 | 2004 Mercedes-Benz C-Class
Describe how to replace a power window regulator
You have to remove the interior door panel. then you can access the window regulator motor assembly. On vws you usually have to remove the assembly as a whole. Go to your local parts store and buy a haynes repair manual for your car they are pretty good. the cost around 15 bucks.
Oct 31, 2009 | 2001 Volkswagen Jetta TDI
How do you repair the side opera lights on a 93 roadmaster
You should be able to access the wiring and light assembly by removing the interior trim panel.
Oct 31, 2009 | 1993 Buick Roadmaster
Can not lock trunk with vallet key-Mercedes 2005 e320
Usually after removing any interior trim, there's a slide clip holding the assy. to the lid.
May 30, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Drivers door wont open inside and outside on a 98 accord
You need to adjust or replace interior latch assembly. You can find out by removing interior door panel and inspecting latch assembly.
May 16, 2009 | 1998 Honda Accord
Rear passenger electric window stuck in down position
That happened to mine, too. The cable that raises and lowers the window broke. I needed a new window motor assembly. If I recall, I got one used for less than $30, and I know I was able to replace it myself, curbside without special tools. You just need to make sure the window glass is taped up and unable to crash once you remove the old motor. The hardest part for me was figuring out how to remove the interior door assembly!
Aug 10, 2008 | 2005 Chevrolet Malibu
Locks & Locksmithing Logo
146 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
