Question about NTL VS2000 Cordless Phone
Handset sometimes does not ring. Small screen on the handset shows what looks like a small flashing bell with a question mark (?) Have replaced batteries but flashing continues. david.attwood4@btinternet.com
eagle338
  • 4889 Answers
SOURCE: faulty phone
Sure sure i will help you out but please specify the model of your phone..If its GE then you will need to keep it connected to the power supply...If the power supply is cut it will br un-registered automatically..
Posted on Oct 30, 2007
SOURCE: No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Posted on Dec 04, 2007
SOURCE: phone handset display continuously showing
Buy a new phone but not a VTECH piece of crap. Thier support sucks and you never talk to a person. It is all automatted.
Posted on Feb 28, 2008
I have no ringing tone (incoming calls) on handset 1 which fits to base station. I have not lost contact with base station hence your remedy is not applicable, all I wish to know is how to get the incoming ring tone back.
Posted on Mar 10, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
I have an uniden exa 2980 and losy manual,how do I obtain a copy.also how do I turn up ring volumn?
Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
Feb 12, 2018 | Uniden Lands Phones
AT&T/Lucent cordless. Why is there no display on the screen?
Perhaps the battery is discharged (dead?) -- is the
"charging" light for the handset (or base, depends
on model) illuminated while the handset sits in the
base or docking cradle?
The original Owner's / User's Manual is easily
downloaded from www.manualslib.com
Look underneath the battery inside the handset for
a small sticker showing the proper model number
to ask for ( ie, CL82659 )
Mar 19, 2016 | Lands Phones
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
Model: kx-tg6641. Handsets are not ringing when somebody calling. During ringing there showing line thru bell at left bottom of the handset screen. Silent mode is turned off.
As per the display of your phone, I assumed that the bell is turned OFF that's why sound is not coming out from the speaker.
OK. Go to the handset direct command menu:
Press Menu
Enter code:
#238 (Silent mode 1=on 0=off)
Then Press 'Save'
To exit, press 'Off'
Other code that may help you:
#160 (0-6 Volume)
#161 (Tone)
Sep 01, 2015 | Bell Lands Phones
Somehow I have a bell icon on the screen at the bottom left with the words OFF beside it and now the phone does not ring only the ring on the fax/printer. Thanks Margaret
Hi margaret, is there a ringer switch either on the phone handset, or is there an option in the the fax settings to go directly to print. The issue sounds fairly straight forward, somewhere the phone ringer, or the settings for the phone to ring has been inadvetently switched off. Some investigation shoud bear fruit
Jun 08, 2015 | Bell Lands Phones
Hi - my 2yrold was fiddling with the handset, and now we have a flashing 'base 1' display. Each time we dial, it reverts back to the flashing message. I've tried unplugging the unit and leaving it...
You 2 year old disconnected the handset from the base. The handset is asking to be connected to the base. If you have the owners manual it will tell you the sequence you need to do to reconnect the handset to the base. If not, google the make and model and get the manual on line. sometime sitting the handset on the base several times in sequence will re sink it to the base.
Dec 12, 2017 | Northwestern Bell BELL 36240 Cordless...
Hi There.. Lost instructions..wanted to know how to change the handset setting/line settings.. want to change handset to different base ?? Hopefully you can assist? Thanks
First, you need to de-register the handset from the current base. Then register it to the new base. On the handset, press Menu then navigate (up/down arrows) to Handset Settings and press OK. Next navigate to Registration and press OK.
For deregistration: navigate to Deregister then press 3 3 5 . Then select which handset to deregister (1-6) (the handset number will flash when it is selected) and press OK. Select Yes and then OK. When the deregistration is complete, press OFF.
For registrations, navigate to HS Registration then press OK. Then move to the base and press and hold the Locator button until the registration tone starts. If all the handset ring, press the locator button to stop the response and start over. Within a minute and a half of the registration tone starting, press OK on the handset and wait until a beep sounds and the symbol on the screen stops flashing.
The user's manual is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG1033S.O#ts . It's in the tab marked Operating Instructions. This will provide additional setting information.
I hope this helps.
Nov 29, 2010 | Panasonic KX-TG1033S Cordless Phone
Panasonic kx-tc1222jxb
If u battery meter shows full then ur lucky coz it aint u battery!
Secondly if u have some basic electronic knowledge and experience, my suggestion would be to open the handset carefully and tune the Variable inductor(it looks like a small silverish device with a black knob) very small. Call on ur loopback number and as soon as the phone rings carefully tilt the variable inductor to resonate to the frequency of the base and when u successfully accomplish this you will hear a ring on ur phone and if not then keep trying the same!
I warn u do it only if u have good experience and im not responsible for the damage of ur phone!!!
Sep 16, 2009 | Panasonic KX-TG1033S Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
NTL VS2000 Cordless Phone Logo
44 people viewed this question
Top NTL Lands Phones Experts
Computer Repairing
Computer Repairing
Cliff
David Burbee
David Burbee
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
