Question about JVC GR-DVL820U Mini DV Digital Camcorder
Trying to capture videos from JVC GR-DVL820 to PC. Please help - have read all links, appears that USB to PC is for capturing images from memory card. I am trying to transfer taped videos to PC (for storage on DVD, etc.). Is there a way to do this with this camera??? I have connected it to PC and it only sees the memory card images. Thanks in advance!
5 Suggested Answers
  • 473 Answers
SOURCE: JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Posted on Sep 05, 2005
SOURCE: JVC GR-DVL300u
get out of safeguard mode
Posted on Apr 14, 2008
  • 435 Answers
SOURCE: JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Posted on Dec 29, 2008
  • 497 Answers
SOURCE: cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 18, 2009
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 26, 2011 | JVC Video Cameras
JVC GR-D23E download video
here is a usb driver for JVC cameras from GR-D20 to GR-D70 for windows XP:
http://odsiebie.com/pokaz/1654699---3329.html it's on free polish server
Nov 28, 2008 | JVC GR-D23E Mini DV Digital Camcorder
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
Jul 05, 2017 | JVC GR-SXM260U Camcorder
How do i put a tape recording onto the pc?
Unless the video is stored on the memory card you cant transfer it directly, you need a video capture device, it is an attachment to your Computer that manages the transfer of taped video copies to digital...
Dec 09, 2007 | JVC GR-D60 Mini DV Digital Camcorder
Can't transfer video from cam to pc
You can't capture the video with a USB cable. The USB cable and software that came with the camcorder are only used to transfer still images.
To transfer video you'll need a DV cable (also known as a Firewire cable) and some additional software. I use Scenalyzer Live. It's not free, but you can download a demo copy to see if you like it before you buy it. Here's a link to the Scenalyzer website:
http://scenalyzer.com/
If you have the JVC manual you should read page 41. If you don't have the manual you can download it here:
http://www.devicemanuals.com/guide/Digital%20Camcorder/JVC/JVC-Compact-VHS-w-LCD-Screen-Camcorder-GR-D370AS-User's-TWpJME56VT.html
The download link is about half way down the left side. It's a little difficult to find, but it's there.
Lastly, all this assumes that your computer has a Firewirre port. Most new computers will have one, but if you do not you'll need to buy and install a Firewire PCI card. Let us know if you need more help.
Dec 04, 2007 | Video Cameras
While capturing the video you have to change the Video mode to PAL or NTFS mode & store the Video's in Memory card,
When you want to transper the video's, remove the card or directly plug in to the camera to Computer USB port
Now you can transper the Movie's easily..
Try it out.
good luck..
Dec 02, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Gr-d290
Hi, You can only transfer still images (photos) with a USB cable. For video, you need a firewire card and cable. That's the way it works.
Mar 17, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-DVL820U Mini DV Digital Camcorder Logo
107 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
