Question about Pioneer Audio Players & Recorders
I have a pioneer cd player (model PD Z84). Six discs can be loaded at the same time. It won't play , it just keep changing the discs. Any help will be welcomed.
SOURCE: Pioneer 301CD Player PD F1009 disc tray jammed
I had this same problem today on my pd-f1007
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Posted on Jan 06, 2008
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
robotek
  • 1512 Answers
SOURCE: Pioneer PD-206 wont power up
Hi tfulton
Try disconnecting from the power and powering it up again to reset the unit.
If it still wont cooperate, the unit will have popped a IC protector in the power supply. Not an uncommon fault. The burnt disc you used may have pushed the tracking servos a little hard and a circuit protector has kicked it. Pop the lid off and look for a black 2 wire device about 4mm across that viewed from above has a D shape. Measure it with an ohm meter....It should read low ohms, if it does not... it has failed. It may be marked as ICPxx(from memory)
A fast fix we used for this is to grab the device and give it a 200 deg twist to short the legs together. Soemtimes(often) the body of the device will break off, just solder the legs left behind.
They have a habit of failingl with no reason, and shorting across them will not affect the operation of the unit, nor put it anything in jeopardy.
OR pull the board out... and replace the device, although I can tell you through experience, they may fail again.
Good luck, if you have any questions, just get back to
me here. :)
regards
Graeme
Posted on Mar 08, 2008
  • 46 Answers
SOURCE: Pioneer 6 disc PD-M455
Hello...if you can try to clean the laser lens whit a smooth cotton pin it may be dusty,,i have had the same problem...don't use any solvent just the pin very carefully,,,maybe you can use a mild solution made of hand dish solvent... and dry clean after...alternative use a cd.cleaning disc...Good luck Ron
Posted on Mar 11, 2008
  • 4234 Answers
SOURCE: U3 error for my pioneer pd-f605 100 cd player
I don't have the service manual with me at the moment and I'm on the road. I'll look up the error code and update this somtime tomorrow.
Dan
Posted on Aug 27, 2008
No disc error with pd-z83m
I had the same problem. I didn't clean the system I just got mad and inserted the cd holder really hard and smacked the radio a few times. Now it's working again. I suggest you do the same.
Sorry for my bad English.
Nov 14, 2012 | Pioneer Audio Players & Recorders
My Pioneer PD-M403 will not play computer made CDs. Why won't they play?
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Take care.
Sep 25, 2010 | Pioneer PD-M403 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
CD changer has gone wacky; won't change discs; Pioneer PD-F5507
Look for either a bad solder joint, or a bad connection somewhere.
Sep 07, 2009 | Audio Players & Recorders
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Pioneer pd-m406 cd changer magazine style
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
54 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
