Question about Compaq Presario 1711T Notebook
No turn on notbook compaq 1711t - Compaq Presario 1711T Notebook
  • Compaq Master
  • 2,385 Answers
Hello The mandatory requirements before you try anything else are the main battery must be installed, it must work correctly, and there must be nothing wrong with the AC adapter or it's connection to the laptop. -Your model is recent enough the main battery must be installed - it won't start up on the AC adapter alone. - The main battery must be capable of being charged up to at least a minimal capacity. - The main battery does not last forever. Typically it works as it should for a year or so then begins to deteriorate - by the second year it can't be charged to anywhere near it's rated capacity. It gets worse as time goes by. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce (you can test for that with a volt meter), and they may get HOT when you attempt to charge them for a while, rather than a little warm, or they may never get warm at all. - If you haven't replaced it since the computer was new, this model is old enough the main battery should be replaced! There must be nothing wrong with the AC adapter or it's connection to the laptop - if there is, the main battery cannot be charged properly. A common thing people do when they unplug the AC adapter is to pull on the cord rather than the plug on the end of the cord as they are supposed to do. Doing that eventually damages the plug and/or the wiring near the plug, and over a longer period of time, doing that damages the jack in the laptop the plug plugs into. The jack in the laptop should move when you wiggle the plug in the jack. Most laptops have an led that lights up only when the AC adapter is plugged in, there's nothing wrong with the AC adapter or it's connection to the laptop, and the AC adapter is charging the battery. That led should come on at least briefly when you unplug the plug from the AC adapter, then plug it back into the laptop jack, even if the main battery is fully charged. The led should not blink on and off randomlyIwhen you wiggle the plug in the jack. If that led never comes on, there is something wrong with the AC adapter or it's connection to the laptop, or the main battery is shorted (check it's voltage). If that led never goes out even after a long time, the main battery is probably no good - replace the main battery. The plug on the AC adapter cord can be replaced, but if you damaged it by pulling on the cord you will probably continue to do that at least part of the time, so since a plug molded onto the cord stands up to abuse a lot longer than a replacement plug, it's often a better idea to replace the cord from the AC adapter to the laptop if it can be unplugged at the AC adapter (a laptop repair place may stock that), or if that can't be done or you can't find that part, replace the AC adapter. The jack on the laptop can usually be replaced but that requires taking apart the laptop and careful removal and replacement of the jack. A laptop repair place does that sort of thing frequently, and often have the more common jacks in stock, though they may have to order one. Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Posted on Dec 31, 2010
    Problem Solver:
  • 15 Answers
I had the same problem and what i did was turned the system off and let it charge for about 2 hours
No turn on
Hello Please check its power cable and switch ,if you still problem then check your power supply or the connector that plug in laptop to power supply . Take care
Dec 31, 2010 | Compaq Presario 1711T Notebook
Drivers problem for compaq NOTBOOK Evo N620c
download from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316684&prodTypeId=321957&prodSeriesId=316682&swLang=8&taskId=135&swEnvOID=1093
Jul 02, 2010 | Compaq Evo N610C Notebook
Battery won't charge
there is a problem of your notebook not of battery yu need to contact compaq customer care they will resolve your queries quickly.
Oct 07, 2009 | Compaq Presario 1711T Notebook
I have compaq presario CQ 40 317TU notbook. i want install windows xp in my notbook. Plz help for this
for XP OS make sure you have a copy of all your driver software so that you can install it after you install you XP if you don't have iinstaller of your laptop you can download the driver HERE
Mar 19, 2009 | Compaq Computers & Internet
Receives beeps on boot then nothing
most likely the ram needs to be reseatedor replaced.
Jan 13, 2009 | Compaq Presario 1711T Notebook
Sound driver problem
i have compaq prsario c700 notbook i instaled winxp but i did not get sound driver wer iget sound driver
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Cant see the icons
Do you have a desktop background?
Jul 04, 2008 | Compaq Presario Notebook
HP Compaq Presario C304NR PC Notebook
my sugestion is to place your ear near notebook and turn on if you hear the hard drive then majure problem but if you hear hdd is quite then it sounds like the fans thet cool the notbook down get this in for repair as soon as you can hope you get it sorted soon good luck
Aug 14, 2007 | HP Compaq Presario C304NR Notebook
Compaq Presario 1711T Notebook Logo
95 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
