Question about Toshiba Computers & Internet
My toshiba laptop will not power on. Disc drive will not start.
    Brigadier General:
  • 8,909 Answers
laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Posted on Dec 31, 2010
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
Nov 11, 2012 | Toshiba Satelite A135-S2286 Notebook
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
Toshiba Satellite L450 Series - no access - black screen - was diagnosed with virus - using recovery disc - appears stuck on
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Feb 24, 2012 | Toshiba Satellite Pro L450 Notebook
I need to replace the hard drive in my Toshiba Satellite M305D-S4830. What size should I replace with (the one it had was big enough). Step by step instructions?
its up to you what size you want to replace it with go onto the toshiba site and there you should be able to get a manual showing you how to do it
Feb 20, 2011 | Toshiba Satellite M305D-S4830 Notebook
How do i replace harddisk in my toshiba p25 s487
Ensure you have your backups up to date and either OS disc or rescue discs to place a new system on your new hard drive.
Remove the larger cover from the underside of the laptop, slide out the hard drive. Remove the old drive from the cradle and fit the new drive to the cradle. Slide it in.
Power the laptop up open the DVD drive and place your restore/PS disc in it and on the bios menu select F12. Set the boot device to DVD/CD.
Boot from the DVD/CD drive and follow the prompts.
When finished, download updated drivers from www.toshiba.co. and restore your backups and programmes.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite P25-S487 Notebook
How to restore toshiba labtop with no disc
Hello
Well, if you have no Installation disc, or no cd/dvd rom in this specific model, you should have a recovery partition.
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
If this procedure doesn't work, you don't have a recovery partition set up, hence, you will need the installation disc.
Hope this can be of help.
Kind regards
Andrea
Dec 01, 2010 | Computers & Internet
Toshiba A65-S1065 powers up but will not start Windows
sounds like the drive is broken. get a new drive then try again. this has happened to me.
hope this helps
Jun 06, 2010 | Toshiba Satellite A65-S1065 Notebook
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Aug 13, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
I just bought a toshiba satellite 5005-s504 on ebay it was shipped to me and all programming has been deleted I need to reload windows xp how do I do this I have a disc for windows xp but the laptop will...
When the computer starts to boot up does it ask you to boot to CD/DVD?
1. If so put the xp disc in the drive and turn on the power when it asks you to boot to CD/DVD press any key. This will start the installation process.
2. If it does not ask you to boot to CD/DVD you will have to go into Bios and change the boot priority to boot to disk drive first. save the settings and do the first step over again
Jan 31, 2009 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
217 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
