We have a Hisense flat screen television (TL 1700). Frequently the on/off button doesn't work. We have to unplug it and plug it back in and that seems to fix the problem temporarily. Any ideas?
  • pjtroendle Jan 01, 2011
    It's been left unplugged for more than a day at times. Since it is more than a couple of years old we will try your other solution. Can you tell me where the power supply board is located and how to change the electrolytic caps?
  • 11,800 Answers
This is caused by a bad signal coming from the the buttons board to the processor on the mainboard. This in turn can be caused by either :
1 - a bad connection to the data cable that joins them - you will have to open the tv and reseat the cables, plug the firmly, or
2 - the power source delivers a lower than needed voltage to the controller of the tv - you will need to test it: take off the back cover , take it out (the power cable plugs into it) and replace the capacitors as explained here
http://www.youtube.com/watch?v=on_2CP52cW4
If the problem returns after that you will have to inspect also the mainboard, on which the processor is situated.
Posted on Jan 02, 2011
    Genius:
  • 1,126 Answers
It is possible that your set might have been hit by a small power surge, and there is some garbage in the processor and if you leave it unplugged for 40MIN, it will reset back to normal. You were doing the right thing by unplugging the TV, but maybe not long enough for the caps to dissipate, to a low enough voltage so the micro processor will then reset. Also if the TV is more than a couple of years old then the electrolytic caps need change on the power supply board, that can cause the same problem.
Posted on Jan 01, 2011
Hisense tv stuck on upgrade screen but isn't updating. Says 0% constantly.
Try resetting the set if possible. If no reset button you can also unplug set while it is still turned on. Then push in and hold the power button for a few minutes. Then re plug unit, cross fingers and push power button to see what happens.
If still does it, then something has to be wrong with your main board circuits.
Nov 24, 2016 | Hisense Televison & Video
Was watching live tv on my seven day old hisense 65k700uwd tv, when I pushed the you tube button the tv went completely blank (no sound or picture) and the remote wouldn't work
Cheryl, unplug, wait 10 minutes plug back in, if this does not reset it, return for refund or exchange.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 04, 2016 | Hisense Televison & Video
Describe your hisense tv ~20in(?) Flat Panel TV. I pushed a button on my universal remote & accidentally locked the TV. How do i unlock it?
I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
Nov 20, 2010 | Televison & Video
My hisense locked and I don't have the original remote
This worked like a charm for me. I used the buttons on the side of the TV, since I've lost the original remote. Good luck! I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
Oct 25, 2010 | Hisense TL1700 17 in. LCD Television
Power up problem
The problem is in the relay built into the power supply. It is magneticly sticking into the off position. Unplugging it kills the field and let's it set back to a neutral position. I doubt the relay is serviceable by itself.
Probably need a new power supply.
May 08, 2009 | Televison & Video
INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Aug 04, 2008 | Hisense TL-3220 Television
HiSence Flat Panel TV, Model TL 2020
Hey Billy Lee,
If you're unsure how to unlock your TV, you may wish to check out Hisense's online documentation for the TL-2020 through the following link:
http://www.hisense.com/en/Support/download_manual.jsp
Instructions on how to disable any feature locks should be included in downloadable files on "page 9" and "page 10" of Hisense's support forums.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 22, 2008 | Hisense TL-3220 Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
