Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
7065 handle came off, broken plastic retainer clip. cannot remove screw that holds the part on
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 360 Answers
SOURCE: Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Posted on Feb 12, 2009
  • 21 Answers
SOURCE: replaced moen 2225 cartridge leaks when valve is turned on
Yes you remove the clip by pulling up  on it.  make sure water is off.  then you can replace the cartridge by puling it out.  make sure that you put new cartridge back in the same way you took it out there will be a H and a C on the cartridge.
Posted on Jun 23, 2009
  • 44 Answers
SOURCE: vestige 7065 how do i remove cartridgi.handle is
Note: You can get a cartridge for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well. Once the water seal is broken and the retaining clip is slid out, the cartridge will pull straight out.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
  • 94 Answers
SOURCE: Where is the retaining clip on older Moen kitchen
it should be under the pivot nut /collar,(where you remove handle from.un screw it and look closely.it is shaped like a horse shoe and may have small hole in it,and is brass in color
Posted on Apr 25, 2010
How do you fix a passenger door handle on a Ford Explorer 1999
inside or outside????????. either way remove the door panel. the rest is easy
Apr 24, 2015 | 1999 Ford Explorer
Rear door handle doesn't open the door from the inside
Sounds like the linkage has come off the handle inside the door. The door panel will need to be removed to gain access to the linkage. Be careful when removing the panel! Some are held on by plastic snap clips, others by screws (some hidden some not), Also the linkage may be retained by a small plastic clip that holds it to the handle itself. If this is broken you can usually find a replacement at a auto parts store in the HELP section or by showing and asking a sales person there.
Jun 28, 2012 | 1999 BMW 323 Series
The driver side power window is stuck open about 4 inches. I'm having difficulty getting thhe door panel off. How do I disconnect the door handle?
remove the screw holding the handle.If you look behind you will see 2 rods. One is for the handle and the other is for the lock.Use a flathead and flip the plastic clips in order to remove the rods from the handle.The door panel will need to be lifted up to remove after removing and retaining clips/screws
Aug 04, 2011 | 1998 Saturn SL
I need to replace the door handle on my '96 honda civic, how do i get it off?
Pop off the speaker grill and remove the three screws securing the panel to the door frame. You do not have to remove the screws holding the speaker to the panel. Remove the window crank. There is a "U" shaped retaining spring holding the handle to the spindle. It can be removed with a special tool or just by pressing in on the panel and loosening the clip with a small flat blade screwdriver. Remove the screws in the arm rest and above the interior door handle lever.
Pull the panel from the door - be careful of the speaker wires - carefully undo the quick connect.
From the top corner, pull down on the plastic sheet.
Remove the square white plastic box that is used as a guide for the control bars.
Locate the exterior handle mechanism. There are 2 10mm bolts that hold the handle to the door frame. Remove them with a ratchet and extension.
Pop the retaining clip (it's green for the left door) free from the lock cylinder control rod, then pull the rod from the back of the lock cylinder.
Covering the back of the lock cylinder is a metal plate. Holding the plate to the cylinder is another "U" shaped spring clip that can be pulled down with a flat blade screwdriver.
After removing this clip, the metal plate will seperate from the cylinder. The culinder can then be pulled free from the inside and the handle from the outside.
Reverse the procedure to reinstall.
Its possible that need check the Honda-Civic-1996-1998-Service-Manual-Part-III
Hope help with this (remember comment and rated this post).
Apr 21, 2010 | 1996 Honda Civic
HOw do you fix a non working outside handle on a 93 buick regal custom?
You will have to take the door panel off and check the mechanism from the inside of the panel. Usually one of the bushings, retaining clamps, or pushrods inside the doors has come loose or has broken. Sometimes the handle mush be replaced because they cannot be fixed. The handle mechanism is usally held on with two bolts which you can access by removing the door panel. You will have to start by taking out all of the screws which hold you door panel on, there is usually 4-6 screws that hold the panel on, sometimes less depending on if they use press type plastic holders to hold the panel on. If you have manual windows then you should buy a tool from the auto parts store to remove your windows crank. There is usually a screw in the middle of the window crank lever that you will have to remove, sometimes its covered, then you slip the tool behind it and pull it off. You can also buy a tool to help you dislodge the slip fitting that hold the door on. Look carefully for retaining screws as the manufactuer has a tendency to hide them. Once you get all of the screws, window crank, and assocaited windows controls off you should be able to pull the door panel up and off and you will have access to the mechanisms inside to repair the door handle. Follow the above procedure in reverse for re installation of the door panel.
Apr 07, 2010 | 1993 Buick Regal
Drivers door won't open from inside vehicle, opens from outside with no problem.
you may have a broken inside handle, open the door, remove screws holding door panel on,then pry door panel off, it has plastic retainers that hold panel on they pry off and pop back when installing panel, once the panel is off you will see if the rod just came off or if handle broke if its the handle replace it remove screww holding it and install new one, some are held with revits, drill revit to remove,use screws to reinstall. hope this helps.
Dec 26, 2009 | 1999 Chevrolet Suburban
Vestige 7065 how do i remove cartridgi.handle is off
Good Luck.
Sep 04, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
I need to remove the drivers internal door panel
Remove plastic studs from door closer. Unscrew three retaining screws. remove grab.
Unhook window winder retaining clip. Best done with small long-nose pliers. window winder retaining clip located inside plastic winder handle section. Will need to prise away winder handle from door slightly to expose clip. locate and gently pull clip from winder shaft.
unscrew door opener / lock assembly retaining screw.
gently prise lower trim retaining press studs from door. remove lower trim.
gently , from rear of door, pull upper trim from door and similtaniously prise upper trim press studs from door.
gently giggle door opener / lock assembly through upper trim . remove trim
gently with flat blade, peel off plastic dust sheeting.
access to inside off door is now possible.
Reassembly reverse of above
Cheers !
ozzy11
Feb 04, 2009 | 2001 Suzuki Swift
Replacing an interior door handle
first remove the door panel after you have completed that remove the 3 bolts holding the handle in place, pull the handle out on the reverse side there will be a connecting rod with a retainer clip holding the rod to the door handle remove the retainer clip and rod and remove the broken handle follow instructions in reverse to reinstall new handle
Jul 19, 2008 | 1988 Ford Taurus
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
79 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
