Common usage things to check:
Make sure you're using high quality detergent that contains both sodium carbonate and aluminosilicates. They'll be listed on the ingredient list.
The detergent amounts given on the usage label of the detergent box are for average water hardness (4-9 gpg). If your water is harder than average, or if your clothes are really dirty, you'll need to use slightly more detergent than what's recommended on the box. If you have really hard water, you may need to add a packaged water conditioner to each load, such as Calgon® or Spring Rain®.
If your water is softer than normal, you'll create too many suds, which will retain gookus. In this case, you'd use slightly less detergent than recommended on the box.
If you wash clothes in cold water only, the cold water should be in the range of 65-75F. If it's too cold for your hands to comfortably be in the water, it's too cold to activate the detergent.
After the washer is loaded with clothes and then filled with water, there needs to be enough head room in the tub for the clothes to swish around in. A properly loaded washer has clothes loosely placed in the tub up to the top row of holes.
Some fabric softeners and detergents have a chemical reaction that can create white deposits (also called 'gookus') on the clothes. Try switching brands of fabric softeners or detergents or not using fabric softener at all for a couple of loads.
