Question about McCulloch FH140A Electric Pressure Washer
Nozzle clogged, can it be unclogged - McCulloch FH140A Electric Pressure Washer
  • 11,896 Answers
Sometimes a high pressure air hose works. Sometimes but not always a paper clip can unclog them. I would try the air pressure first. Seems to work the best if your not going to replace them.
Posted on Dec 31, 2010
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
www.inkmagic.com/shopcontent.asp?type=Unclog...Inkjet_Printhead...
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
www.inkmagic.com/epson_clogged_printhead.htm
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
How do I unclog the inkjet nozzles on HP Photosmart 6510?
dip the nozzles side of the catridge in ammonia solution for two hours clogged ink will be dissolved and the nozzles are free.
Nov 24, 2014 | HP Photosmart 6510 Wireless e-All-in-One...
Yellewo does not print
Must replace the nozzle/ cartridge carriage as the nozzle for yellow is most likely clogged
Aug 31, 2014 | HP LaserJet 2840 All-In-One Printer
Why does dishwasher leave heavy soap ****
There could be two reasons
1. You are not using dishwasher detergent which is low foam compared to normal dishwashing liquids which are high foaming.
2. The rotating nozzles in the sprayer are blocked. This happens when you attempt to wash bottles with paper stickers still on them which dissolve and clog the jet spray nozzles. Look closely at the nozzles and remove stuck paper with a safety pin to unclog the nozzles.
Aug 14, 2014 | Dishwashers
How to unclog washer nozzle
unplug hose to sprayer and blow air from opposite side
Dec 28, 2013 | 2005 Nissan Pathfinder
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
Feb 13, 2011 | 2004 Chevrolet Cavalier
Windshield washer clogged 2001 MB SL500
use a small needle or push pin to unclog the nozzle and to adjust if needed after unclogging.
Nov 17, 2010 | 2001 Mercedes-Benz SL-Class
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Jul 30, 2008 | Kenmore 22812 Bagged Canister Vacuum
Black ink
It's been my experience when an inkjet printer produces unfavorable printing results ("scan lines or no color) the most common cause is clogged print nozzles. The most common cause of clogged print nozzles is lack of use and the ink dries and hardens in the nozzles.
Your particular model of Lexmark as well as other brands generally have a utility to assist in unclogging the jets by forcing ink through the nozzles. This does "waste" ink, but it is the "easiest" way to attempt in unclogging the nozzles.
For your model try the following: (This is an excerpt from the Lexmark site.)
  1. Load paper.
  2. Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the clogged nozzles to clean them.
  5. Print your document again to verify that your print quality has improved.
  6. If you are not satisfied with the print quality, continue with step 7 and then print your document again.
  7. Wipe the print cartridge nozzles and contacts:
  1. Remove the print cartridges.
  2. Dampen a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown. acrtclnn.jpg
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown. acartclnc.jpg
  5. With another clean section of the cloth, repeat steps c through d.
  6. Let the nozzles and contacts dry completely.
  7. Reinsert the print cartridges.
  8. Print your document again.
  9. If the print quality does not improve, repeat step 7 up to two more times.
  10. If print quality is still not satisfactory, replace the print cartridges.
Nov 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
McCulloch FH140A Electric Pressure Washer Logo
235 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
