Question about Sony MDS-E12 Mini Disc Player
Eventide Eclipse Hi, I have an Eventide Eclipse 1119-000 Harmonizer effectprocessor. Unfortunatelly is completely dead. Is there anyone knows a repair shop where my Eventide can be repaired? Thanks for your help in advance. Gabor, Hungary my email address is: fejesker@externet.hu
5 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Sony KP-46WT520- STANDBY
Diode 6301 D6116 D6117
Posted on Jan 01, 2009
SOURCE: The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
Posted on May 28, 2009
firesnake09
  • 2923 Answers
SOURCE: Hi. Does anyone have contact no for sony repair
There is no authorized Sony repair center in Doha. But you may go to Al Fardan or in Souqe (near in gold souqe and dow round about) and you will see lots of repair shops there. I believe that there's a Sony store in souqe and you may ask them if they have an authorized repair shop around Doha.
Posted on Sep 06, 2009
  • 966 Answers
SOURCE: CPU dead? Please help
check if power supply is ok and cable securely connected.
check if the power switch is ok - sometimes it takes several attempts to power on.
check if you can see green light inside the cpu.
when was the last time cpu worked?
Posted on Feb 25, 2014
Where to find solar eclipse filter len for my Tasco Galaxsee?
talk with camera and telescope supply shops
Sep 11, 2017 | Tasco Optics
Does anyone have schematics for (any) vocal harmonizers.
The circuitry is quite complex inside these units and-so If it's a broken wire then MAYBE you could repair it, but if it's one of the multitude of 10 to 40 pinned surface-mounted IC's...well, good luck.
Oct 25, 2012 | Digi-Tech Digitech Vocalist Live 4...
I am seeking this time the uswer manual for the Eventide BD980 profanity delay
Eventide sells the manual for $25. The link for it is here. New equipment manuals are available for free in electronic form - older stuff like the BD980 have manuals that predate electronic manuals. Apparently they have plenty printed versions to sell rather than scan one and making it available for download. Check on the Eventide Forums for a user that may be able to help with a scanned copy.
Jan 26, 2012 | Radio Communications
Hook up eventide harmonizer to the pmp 6000
There are many models of the Eventide and how to hook them up will vary and depend if you have multiplle mics that are to be serviced. If you have multiple mics, I would be tempted to run the mics into some of the channels of the PMP but tur their faders to zero and send them to MONITOR 1. Come out of the MONITOR 1 jack to go into the Eventide and then run the Eventide into one of the line inout channels like 19/20. You would need to use balanced connections and some adapters from XLR to 1/4 inch to make the connections. There are MANY ways to configure this and depends what you are trying to do. If all audio is to go through the Eventide, then wire it as an "INSERT" for the power amp. This would require a special cables.
Jan 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
After a few minutes of use, there is clipping and sound cutting out with the guitar through. Vocal and harmony are fine. I tried using different guitar cords, different guitars, different amps to no avail....
I know you hate this answer, but it needs to be repaired. It has a circuit board inside, and there's really not a work-around. But it is broken. I totally understand about not wanting to send your gear out, especially if it's a pedal board you have set just right, and are completely usweed to using. You'll be a lot happier with it if you get it fixed though. Or find another one on eBay. I sold all me Digitech pedals when I got my Pod - but that's just me, I use a lot of distortions and it fit the bill better for me. I used Digitech pedals for about 20 years and thought I would hate anything else.
Take care.
Mark
Jun 05, 2009 | Digi-Tech Digitech Vocalist Live 4...
Olympus repair shop
I dont know about manila
heres one witch provides free repair estimates
http://www.advancecamera.com/repair/
also look in the fixya front page, under the top experts is the service finder, put your zip code there and try to find one.
Apr 21, 2008 | Cameras
Dead tv
That is typical with these units, The Horizontal output transistor and flyback go out in the RCA's 9 10ths of the time and causes this situation.
Sep 15, 2007 | RCA F32669 32" TV
Sony MDS-E12 Mini Disc Player Logo
89 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
