Question about Taylor 1524 Wireless Indooroutdoor Thermometer
Remote temperature shows only HH.H or LL.L what's wrong?
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
I recently purchased a 39" Proscan TV from HH
If the remote is not programmable and DirecTV cannot supply codes you may have to use two remotes
Dec 06, 2012 | Televison & Video
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
What causes the temp reading of LL.L?
The SkyScan temperatures only register a certain range, typically -4F to 158F. If it is below this range, it will read LL.L and above it will read HH.H. However, I have been having trouble with mine reading the correct temp, so I often get very whacky numbers, and LL.L is becoming more frequent. Hope that helps!
Dec 30, 2010 | SkyScan 86742 Digital Atomic Wall Clock
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
Nov 01, 2010 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
How to change the time format from 24 hour to 12 hour in windows 7 thank u.
  • click on Start > Control Panel, and choose Regional and Language Options.
  • Click the Customize button underneath the Standards and formats section.
  • Click on the Time tab and change the time format to H:mm:ss (note the uppercase H) and press OK
  • Below that button, you’ll also see an example of how each setting is currently configured for Number, Currency, Time, Short Date, and Long Date.
  • Type uppercase H or HH to Display time in a 24-hour format
  • Type lowercase h or hh to Display time in a 12-hour format
  • Type two characters, HH or hh to Display leading zeros in single-digit hours
  • Type a single uppercase H, or lowercase letter, such as h, m, or s to suppress the display of leading zeros in single-digit hours, minutes, or seconds
  • Type lowercase t to display a single letter to indicate AM or PM
  • Type lowercase tt to display two letters to indicate AM or PM
  • Type single quotation marks (’) around text to display text
  • Aug 10, 2010 | HP Computers & Internet
    How do i change the time on my samsung prostar 816 phone?
    1. Enable technician programming mode
      • Press "#" - "PROGRAMMING" is displayed
      • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
      • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
      • Dial "1" to enter program mode
      • Press "#"
    2. Press "#" key - "PROGRAMMING" is displayed
    3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
    4. Enter the new date
      • YY = Last two digits of the year
      • MM = Month (01 - 12)
      • DD = Day of the month (01 - 31)
      • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
      • HH = Hour (Use 24 hour clock)
      • MM = Minutes (0-59)
    5. Press "#" - new date is saved
    Jul 24, 2009 | Samsung Prostar 816 Phone
    Remote Sensor
    make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
    Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
    Taylor 1524 Wireless Indooroutdoor Thermometer Logo
    301 people viewed this question
    Top Taylor Measuring Tools & Sensors Experts
    Cj Allyn
    Cj Allyn
    Level 1 Expert
    Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
