Question about HP OfficeJet J4580 All-In-One Laser Printer
Replacement ink cartridge needs to be installed. Cannot locate cartridge housing.
  • 4 Answers
These instructions are for color or black cardridges. Turn on the printer by pressing the power button. Flip down the front access door by grasping it on the upper right corner (just under the scanning bed) and pulling it down toward you. the cardridges will automaticly move to the right give you access to them. Press down on the top of the ink cartridge. This will release the cartridge. Slide it forward and out of the machine. Peel off the cover from the ink cardridge. This is a pink piece of plastic /tape like lift-off tab. Lift it up and off the cartridge.
Put the new cartridge inside of your Officejet J4580 by inserting it, label facing upward, into the open slot. Press it back into the unit and down lightly. You will hear it click into place. Close the access door. Wait for the alignment process to complete that will most likely require you to print a alignment page and place it in the scanner bed then press "OK".
I think thats about it
Posted on Dec 31, 2010
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
I want to replace black ink cartridge and cannot line up the cartridge housing to get at the cartridges
you need to press the feeding button for 10-15 seconds for the printerhead to park at the ink replacement position.then after that you can replace the cartridge that you need to replace
Apr 27, 2011 | Epson Stylus C86 InkJet Printer
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i find where to install the ink at?
scaner bed lifts up from the front and, you will see ink cartridges. Printer should be "on" when you lift scaner bed, so that ink cartridges move to the proper location for replacement.
Oct 05, 2010 | Lexmark X2500 All-In-One Printer
What ink cartridges does a canon mp520 take? currently using 5 PGBK black, have been told I can use 8 black, but don't know how to install it
Your printer uses 4 cartridges: PGI-5 Black and CLI-8 (Cyan/Magenta/Yellow). Unless you have a slot for a fifth cartridge, CLI-8BK cannot be used in your printer.
As for installing new cartridges:
  1. Turn your printer on.Open the printer's lid. The printer will automatically move the ink cartridges to the center of the opening.
  2. Unplug the printer's power supply cord from the electrical outlet to avoid the risk of an electrical shock.
  3. Remove the printer cartridges by first pressing down on the top of each cartridge housing. Pressing down on the cartridge housings will cause the top of each housing to automatically lift up, thereby exposing the cartridges. Lift the cartridges out of each cartridge housing to remove them.
  4. Install the replacement ink cartridges by first removing the orange safety tape located on either the top or the bottom of each cartridge, depending on the particular type of cartridge. The safety tape ensures that the cartridges do not leak ink before being installed. To remove the tape, simply pull the orange tab on the end of each piece of tape away from each cartridge. Position each cartridge into its cartridge housing so that the printed words on top of the each cartridge faces towards the front of the printer, then close the tops of the cartridge housings.
  5. Plug the printer's power cord into an electrical outlet, then close the access panel by pressing down on the panel.
  6. Turn the printer on and allow the printer a few minutes to recognize the new cartridges, then insert at least three pieces of paper into the paper tray, which the printer will require to align the cartridges.
  7. Align the new cartridges by selecting either the "Clean and Align" or the "Cartridge Alignment" option, depending on the particular printer model. Some Canon models require the user to align the cartridges through the printer's software program. Select the "Print Properties" option in the printer's program, then select the "Clean and Align" option. The printer will produce several printed pages to confirm that the cartridges have been aligned. Other Canon models allow the user to align the cartridges directly from the printer. These printers features a display screen on the printer. Press the "Menu" button on the display, then use the arrow keys to select "Settings." Press the "OK" button, then use the arrow keys to highlight "Maintenance." Press the "OK" button, then use the arrow keys to highlight "Manual Head Align." Press the "OK" button, then use the arrow keys to highlight "Yes." Press the "OK" button one final time, then allow the printer to produce the printed pages confirming that the cartridges have been aligned.
Apr 07, 2010 | Canon PIXMA MP520 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
E5 error
HI ...
This error comes in when the cartridge is not installed correct ... I would suggest you remove and then re-install the cartridge using the below steps:
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have installed a replacement ink cartridge and the printer is not recognizing it. Same problem, replacing ink cartridge but not recognized.
Oftentimes you must do a self cleaning plus realignment with newly installed ink cartridges. Try to locate the manual on performing these tests and it should get you started. Also, look to see if your new package came with a self cleaning kit to clean the heads on the cartridge, but be careful not to damage the parts -which are sensitive. Hope this helps
May 27, 2009 | HP Photosmart C5180 All-In-One InkJet...
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
Seeker5211
Seeker5211
