Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I overfilled my spa, the indicator for the temp is lit, but only dashes appear and nothing works.
    Top Expert:
  • Dream Maker ... Master
  • 8,686 Answers
No flow check recirculation pump
Posted on Sep 20, 2017
1992 Nissan D21 , left turn signal dose not work , changed bulb and relay , still dose nor work. What next?
Next is probably the turn signal switch. If you have a voltmeter, however, you could be more likely to find the problem, using it to test for voltage at places in the circuit. So I guess you might also need a wiring diagram along with the voltmeter...
If you have neither a voltmeter or a wiring diagram, use logic to think the right turn works so the fuse is good, and if the right turn works, power is going to the switch, and out correctly for the right side, but seems nothing for the left, ( DID YOU CHECK NOT EVEN A BULB DIMLY LIT ON THE LEFT SIDE, FRONT OR BACK? AND ALSO THE LEFT TURN DASH INDICATOR IS NOT LIT?) If nothing lights up for left side, the power is probably lost right in the 25 year old turn switch. That's where you would check for power out (on the proper wires) with a voltmeter- no power means switch is bad. But if the power comes out of the turn switch for left side, then you have to look further along in the wiring , probably not far from the switch connector if the dash indicator bulb is also not lit....It probably is your turn switch.
Nov 25, 2016 | Nissan Cars & Trucks
How long should a 2007 eclipse spa take to heat up??
Usually spas heat approx 5 degrees an hour. If its been a day or so and your water isn't up to heat, you probably need a new heating element in your spa. Check the voltage at your heating element, and on your topside there is usually a heat indicator light that should be lit. If it has correct voltage at heater and the indicator light is lit, heater burned up. If you have incorrect voltage at heater check fuses for a possible blown fuse and see which pump it goes to, that could be your problem.
Mar 09, 2014 | Pool & Spa
My 2006 hot spring grandee spa won't heat.
Have you checked the heating element? Is the spa showing it is heating up but does not? That would indicate a bad temp sensor.
Rod
US Parts Center
Jan 06, 2014 | Intex Pool & Spa
I have a fairly old Leisure Bay hot tub and everything appears to be working great except for the heater. The temp display flashes 199 continuously and the water is not being heated. The water is cold and...
You have a faulty spa pack. Sorry to be the bearer of bad news but it will cost you more than what the spa is worth to fix it. Since this post is from May of last year I'm sure you found that out already. If I'm correct give me an endorsement so people know that I can help them. Thanks!
May 07, 2012 | Pool & Spa
Digi dash lights up, but no indicators are working
these instrument cluster have many problems one is loss of illumination which requires dissassembling and resolder cold solder joints ..other is your problem in dash not responding if you have some mechanical apptitude.... you can take off back plate and then take out screws to the back circuit board remove board and clean all the contacts ,.,,,,do not pull up the other board you will have hell if you do let me know
Aug 31, 2009 | 1984 Chevrolet Corvette
The ionizer indicator does not light up
Push the fan speed button for 3 seconds.
Aug 30, 2009 | Heating & Cooling
Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
May 17, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
69 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
