Just got a new tv and on satalite. The picture is very snowy. Help!
  • 876 Answers
Check all connections, if necessary, use the diagrams in the manual to make sure everything is connected as it should be.
Check your Input.
On your remote select TV
Then TV input
You should see a small menu on the screen
Select Satellite or HDMI
Select Select DTV or Dish
You should now have a good picture.
If not, call your Satellite TV Company right away and they will help you troubleshoot. The number will be on the contract they gave you. I can't give you the number without knowing which Satellite TV you have subscribed to.
Good luck to you.
Posted on Dec 31, 2010
  • Gayle Ashbach
    Gayle Ashbach Jan 02, 2011
    Did this solve your problem?
My bush 42 plasma tv has a snowy picture
Check all the input connections. Snowy picture cane be due to weak input signal.
Mar 09, 2013 | Televison & Video
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
I recently purchased a lg 42ld400 a few wks ago and can't seem to get the picture clear when I saw it n the store it was clear and bright with excellent color while few of my channels are good most look a...
Go into the tv menu.Tries all setting resetting to factory setting,best result.No high backlight setting will not shorteen LCD screen panel life.It design for life span of 6 to 8 hours of tv viewing in 7-8 years at least.The store probally have high end HD satalite signal.U just have basic cable signal only,am i wright?
Dec 17, 2010 | LG Televison & Video
Tv screen is black everything is plugged in Guide will come up but no picture
This problems,it not the tv, it is the satalites boxes or the cables boxes are the problems.Tries unplug the satalites boxes or the cables boxes for about an hour.Replug those boxes back in now those boxes should be resetting itself and updating it software.U should have picture now,if not call ur cables or satalites providers,get a replacement boxes.
Nov 25, 2010 | Sony Televison & Video
Snowy pictures
The dish left behind it just a shell to recive signal,no signal,must pay to recieve channels,like cable or satalite signals.Tries,get new cable,to get signal or must buy a digital antena,or roof antena to get new digital signals.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
We have a new vcr snowy
It seems that you need to take the new unit back for exchange, since you are using the same output for the vcr and the dvd and your dvd is giving you a good picture, the vcr is acting up and since it's new either exchange or repair will be needed.
Sep 01, 2009 | Philips Magnavox TS3260C 32" TV
13 TO 14 YEAR OLD SANYO TV SHOULD I GET IT FIXED
You try to play the video tape or DVD. If picture still snowy, the picture tube is getting old. Buy a new one, do not repair it will cost almost a new set.
Aug 12, 2009 | Acer Aspire One AOA110-1588 Notebook
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
TV intermittently goes snowy.
time for a new tuner probably about 150-200 bucks to fix
Jun 13, 2006 | Mitsubishi PD-4001 40" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
