Question about Oceanic Air Xs 2 Integrated Inflator Octo
I am looking for parts for a Oceanic Air XS 2 octopus. Can you help?
Where in New Zealand can i buy a holden vectra octopus hose
2001 Holden Vectra Reviews - Carsurvey.org
www.carsurvey.org > Holden > Vectra
  1. Cached
  2. Similar
Aug 4, 2016 - 2001 Holden Vectra GL 2.2 from Australia and New Zealand ... 'Octopus' coolant hose blew. This is stupidly designed by some idiotic engineer ...
PartsWorld : Holden Vectra Parts - Right Parts, Right Service, Right Price
https://partsworld.co.nz/parts/holden/vectra
  1. Cached
  2. Similar
Not logged in ( login ' register ). PartsWorld is New Zealand's Largest Auto Parts Recycling Chain ... Holden Vectra Parts - Select a Series. help. Don't know your ... Missing: octopus
Search Results for radiator hose js vectra - Telstra Media Search
search.media.telstra.com.au/?location=&searchIndex=australia...hose...vectra
  1. Cached
  2. Similar
Products 1 - 20 of 103 - TBAP Radiator HOLDEN Vectra JR/JS 2.5L/2.6L 6Cyl Auto . ... /catalogues/hose-application-catalogue-aus-nz-october-2012.pdf.
Holden Vectra Heater Hoses ' Sparesbox
https://www.sparesbox.com.au/vehicles/holden/vectra/heater-hoses-category
  1. Cached
Shop Holden Vectra Heater Hoses online at Sparesbox Australia. FREE Shipping on orders over $50. Missing: zealand ‎octopus
Too expensive to repair - what next? - Servicing - Automotive ...
forums.whirlpool.net.au > Automotive > Servicing
  1. Cached
  2. Similar
Jan 5, 2011 - Rather than scrapping, get the bottom hose fixed (Should be like ... If you do end up buying a new car, always buy japanese or commodore/falcon. ..... Holden vectra, If it is V6 vectra i can tell you right now it wont be the head gasket. .... broadband · Regional · Last century; International: New Zealand ISPs.
Holden ' Car parts & accessories ' Trade Me
www.trademe.co.nz > Trade Me Motors > Car parts & accessories > Holden
  1. Cached
  2. Similar
Holden for sale in New Zealand. Buy and sell ... Holden Commodore VL, Manual steering Rack & Inter shaft .... Holden VT-VZ Front Electric Window Regulator.
New Zealand can buy holden vectra octopus hose Google Search
Nov 11, 2016 | Holden Cars & Trucks
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
The suivel of the second stage eos oceanic does not slacken remains giving turns
I think you mean the adjustment knob, because the swivel should always be able to move, it allows for better hose management. It can be removed but I do not see the swivel on the 2nd stage in that picture
If it is the adjustment knob you will need parts from an oceanic dealer or try scubaboard.com.You might be able to get some grey market stuff It Keep in mind scuba equipment is life support gear and someone could get hurt if it is done wrong
Apr 05, 2011 | Oceanic EOS Regulator Octo Safe Second...
Where can I get an inflator for an Oceanic Cabo BC?
Inflator hoses on the most part are fairly universal and are widely available mail order from the internet, just google for your nearest online scuba store. Cost about $20 us. Hope that helps
Aug 14, 2010 | Oceanic BC Accessory Kit - Buoyancy...
My older air2 failed, the interior parts corroded
IF the used reg works, at $40 you're likely money ahead. Has the used DualAir you have in mind been looked after lately?
Remember, life support equipment should be WELL maintained and serviced annually by an authorized repair person. What's your live or the life of you buddy worth? Servicing your Air2 would be in the neighborhood of $50, depending on how rotten how many of your corroded parts are. Last I knew, if you buy a Scubapro reg and have it serviced *annually*, as is prudent, the parts are free.
Nov 11, 2009 | Alert Scuba-pro Air 2 Regulator Octo Dive ...
I have an oceanic Dive Pro Plus Not a Plus 2. Need the manual
This might be the right link.
http://www.oceanicworldwide.com/pdf/12-1968-r03.pdf
Jun 25, 2009 | Oceanic Scuba Diving & Snorkeling
I have an oceanic console with compass,computer , and air pressure. Now I am getting air leaking out by the compass hole. Can the pressure seal be replaced? Thanks for any help. Donald
It's probably the pressure gauge.. before you replace it, put it in some water to see where the leak is actually coming from. If it's coming from inside the gauge housing, it's time to replace it. If it's from where the hose is connected, there's a little spindle inside the connector between the gauge and the high pressure hose. Those frequently get corroded and start leaking. It's a cheap little metal tube with an O-ring on each end - those get brittle, crack and leak... the spindle is a cheap part at your local dive shop.
Apr 27, 2009 | Oceanic "Veo 100" Dive Computer Triple...
Scuba Tank Setup Question
Ideally, you should have someone who is certified in regulator servicing to do this for you. Otherwise, you may be endangering your life.
Dec 01, 2008 | Aeris A1 Octo
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Oceanic Air Xs 2 Integrated Inflator Octo Logo
118 people viewed this question
Top Oceanic Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
