Question about Huffy BMX 20" Boy's Rock It Bike
The handle bars keep moving from left to right, how do I stop this from happening.
Get some super gorrila glue you can buy them in any hardware store there like 5 dollars put some in your hand and rub then in the bars and stem and sticke them together tighten the bolts and wash your hands wait to 1 to 2 days to ride
Posted on Dec 27, 2012
  • 1,514 Answers
There should be a nut at the end of the handlebar stem, where it goes into the bicycle frame. The nut fits around the stem and screws into the frame. Tightening this will solve the problem
Posted on Dec 31, 2010
The key won't turn when I put it in.
You grabbed someone elses bike. If it has steering lock and the front fork is forcing it to move from lock, it puts too much stress on the plunger to turn the key. Try turnong toe handle bars all the way left or right when turning the key. Also you need to keep oil on the steering lock plunger so it doesn't corrode and jam.
Jun 14, 2015 | 2007 Honda Shadow Spirit
Times when im stopping i hear a viberation from the fairing . but its hard to tell where its comming from.im sure its not the brakes.
I have always been annoyed with this on my 08 FLHX. Honestly, I fixed alot of the problem zip tying all the harnessess in the fairing. Also, the bottom of the radio unit sits almost right on top of the bolts for the handle bar clamps. I removed the radio unit and put a strip of 1/8 thick rubber on the bottom of it. That keeps the bottom of the metal radio housing.
You steering head might need to be lubed also...mine had none in it when I got it. Put the bike on a bike jack and lift the tires off the ground. Turn the handle bars to full right position and release. Watch the bars swing left to right. If it swings back and forth, more than 4 times, before coming to a stop in the straight position, it might need to be tightened a bit.
You are never going to get rid of it all...I have tried. But you can get most of it. Turning the radio up really loud helps this problem too!
Feb 05, 2011 | 2008 Harley Davidson FLHX Street Glide
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Oct 12, 2009 | GMC Denali Road Bike
How do you open a bugaboo frog pram stroller
To open the Frog, follow the steps below:
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle out with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
Sep 28, 2009 | Bugaboo Frog Stroller
Battery icon flashing
Your Stator shorted out and is charging to hi, 17-18 volts. Turn your key off, put your brake on (on the left handle bar) lock in place. Push your override (yellow button on left handle bar) wait about 5-10 seconds, now turn on your key and start the bike. Keep pushing the overide button once v2.1 goes away and you'll get into the voltage of the bike. rev it up to 4 or 5000 rpm, what is the charge, my guess it is around 17 or 18 volts. rebuild your stator
Sep 05, 2009 | Polaris ATV
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
Having problems with gears on my Apollo LSX 1.1 mountain bike
Sounds a lot like cable stretch. Have a local bike shop replace all the cables and do a derailleur adjustment. Costs is usually under $40 complete.
Apr 17, 2009 | RTO Bicycling Complete Guide to Bicycle...
Bugaboo Gecko Collasped Chassis won't open.
To open the Gecko, follow the steps below:
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle outwards with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
Mar 05, 2009 | Bugaboo Gecko - Green Standard Stroller
I HAVE A SONY KLV-40U100M IS THERE AN ADJUSTMENT FOR HORIZONTAL AND VERTICAL. MY PICTURE IS MOVING ACROSS THE SCREEN FROM LEFT TO RIGHT. THERE ARE GRAY BARS SEPERATING THE PICTURE. COLOR IS ALSO MISSING.
You've got more happening than an adjustment. There is an IC that handles the sync and my guess is that is bad. You'll probably need a pro if you're not familiar with TV circuits.
Feb 18, 2009 | Apex Digital AT2702 27" TV
Huffy BMX 20" Boy's Rock It Bike Logo
196 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
