Question about Samsung SCH-a930 Cellular Phone
My A930 has taken too much liquid way to tell if it is the battery, the charging port or the LCD that renders it black/dead/off-appearing (probably really off and no juice and no way to generate more)...they don't have extra batteries, no such old phones, and I need to get my pics and contacts off, in some manner (accessing the chip memory, etc.)...contemplating other batteries to try, but if the electronics to connect are problematic, no matter what battery hooked up, what other means can feasibly be put together, McGuyer style, for accessing the data in one last jury-rigged manner? Thanks!
  • 89 Answers
SOURCE: samsung e250 limited network
phone has the virus get it checked with some one professional bye
Posted on Oct 02, 2007
SOURCE: Continuous Limited Service display
i have the same phone and which has the same problem i rang customer service to see if they could help they told me to try my simcard in a different phone and the sim works no problemwithsim they told me it could be the phone that is broke only had the phone 3 month
Posted on Oct 24, 2007
  • 62 Answers
SOURCE: samsung slide lock
Yes that's possible with every phone just go on settings, security phone settings on automatic key-gard(keyboard) and turn it off. But before you need to know the code for locking and unlocking like in all nokia is green button and *.Not sure for samsung.
Posted on Jun 10, 2008
SOURCE: My phone will not hold a charge at all. I've
Remove the battery and test it with a similar phone to ee if it will hold charges, if it does, it means the battery is good, but if otherwise change the battery.
Next place to look at is the charging port, check with a similar battery and charger to see if it will charge, if it doesnt, change the charging port.
Also test your charger with another similar phone to see if it will charge, if it does, it means the charger is good.
Best regards.
Posted on Feb 07, 2010
  • 291 Answers
SOURCE: I need to copy the contact list from Samsung phone memory to the
you need a third party program to do this, look for the application like pim back up, contacts backup and download it from your phone to install, run the program and back up the contacts. but you need to install this program to both phones.
hence if you cannot find one, use your sim card's utility. copy the contacts to your sim, insert it to your blackberry and copy the contacts from your sim to your blackberry.
i am afraid there is still no way you can back up your contact list in your samsung phone to your memory card. even if you use your samsung studio or samsung pc suite, there is no possible way to copy the save phonebook contacts to your blackberry, they have different file extensions. you can save your samsung contacts as npf, csv, or vcard extensions. you can save your contacts to your memory card as csv or vcard, but i just don't know if blackberry has the capability to browse and save the contacts in this file extension from your memory card.
so the only possible way is to back it up using your studio as vcard, and since blackberry can sync to outlook, you can sync your phone book contacts from outlook to your blackberry..
take care..
Posted on Mar 11, 2010
Both handsets have gone dead
Sadly that does happen tho not often .
Nov 14, 2015 | BT 4500 Cordless Phone - DECT - Satin...
Does not start, battery ok. alternator and starter test out ok
The car battery has 6 cells, each cell holds 2 volts, and connected in series adds to 12 volts. Just like your flashlight, each battery hooked in series results in increased voltage. Its possible one cell is not holding a charge, which slowly drains power from adjacent cells. In battery series connection, if one cell won't hold a charge, electrons will flow to lowest cell voltage in attempt to equalize voltage. So when one cell drops to less than 2 volts, the electrons from other cells will flow to this cell to recharge and bring voltage up to equalize voltage level. To diagnose for dead cell in 6-cell car battery, remove the 6 caps to expose the electrolyte liquid AFTER you have recharged the battery for 20 minutes with 10-amp charger, or until "fully charged" indicator comes "on." With a digital voltage meter set to 5 volts DC reading, connect the negative black probe to negative side of battery and touch the liquid electrolyte with the red positive probe. The voltage meter will display the voltage reading on each cell as you move the red positive probe from one cell to another. Make a note of each voltage reading from each cell. Wait one hour or more, then take another reading of each cell. The cell that has the lowest reading is the one that's draining power from the adjacent cells. A normal battery will show no change in voltage level between the first and second reading an hour later. A defective battery will show a drop in voltage to indicate one or more cell is slowly draining power to gradually render the battery completely dead 36 hours later.
Nov 29, 2013 | 1999 Toyota 4Runner
Livescribe smartpen (Echo) not able to charge
Sounds like the micro USB cable is defective and needs to be replaced. But, first try the cable on another USB port to be certain that the USB port is OK.
Hoope this helps.
Jan 05, 2012 | Smart Pulse Livescribe pen
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Charge port is dead. I plug in the battery charge chord or the car charger and the phone doesn't respond.
You have tried to charge in different ways and still the phon is not responding becuase of some problem in charge pin in the mobile.Contact your nearest vendor they ll change the pin for you and the mobile will get the input(charge flow)
Nov 03, 2009 | Samsung SCH-a930 Cellular Phone
My motoflip is not charging
Your battery is dead. You need to change it. One more thing you can check before changing your battery put your battery in some other handset and try to charge it through that charger if it works then your chargers output voltage is wrong change it.
Jun 16, 2009 | Cell Phones
Tracfone-motorola double minutes does not work at all
If you have pets, they might be responsible. If not, be careful, because you might have a leaking battery.
Feb 24, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Htc 8125
there will be some problem in the charger or in the charging port of your cell ..
just have a check with the charger first with another mobile if needed replace it ..
if you still persist the same problem then there may be some problem in the charging port of your cell ..
the charging port may be is in loose contact ie it might not be touching the motherboard of your cell correctly just have a check by opening the cell if you are good at opening if needed replace the charging port ...
rate my solution
Sep 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Razr V3x
The internal phone software needs to be "reinstalled".
Take it to a service center, they'll know how to do that. The phone will not charge, will not power on and will not accept any input from the keyboard or the USB port except the correct software.
If you try to reload the internal firmware by yourself (there are guides in internet telling how to proceed) be aware that you can render the pone useless beyond any repair.
May 02, 2008 | Motorola Mobility RAZR V3
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
Samsung SCH-a930 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
