Question about Air Tools & Compressors
Hi i am using a technikka aircon and when the yellow timer light flashes there is no cooling and as soon as the yellow timer light goes of its starts to cool.my problem is how do i keep that yellow timer light off?coz it just wudnt go off by pressing the button on the remote.
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
SOURCE: MITSUBISHI ELECTRIC'S AIRCON REMOTE CONTROL ICON
lock out controllers
Posted on Oct 20, 2009
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
The fans runs but does not cool,Timer light flashes 4 times
what is the make of aircon and do you mean that both indoor and outdoor fans run
Oct 06, 2015 | Heating & Cooling
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
May 14, 2008 | Fujitsu 24C1 Air Conditioner
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
