Question about Sony BRAVIA KDL-40V3000 Television
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the picture came right again. The problem came back again this week. The entire screen is covered in the white, green and black vertical lines and dots. The picture is very bad and it is hard to make out the image. Occasionally for a short time it is better with only some small white dots showing. Does anyone know what the problem is and how much it will cost to fix?
    Sergeant:
  • 283 Answers
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Posted on Apr 28, 2017
  • 3 Answers
SOURCE: Vertical green line on screen
If your set is a plasma, this can be one of two problems : either there is a loose connection (one of many, many connections) between the plasma screen and the driver board, or one of the transistor devices has blown. Try GENTLY applying pressure to the opposite ends of the TV to give it a subtle "twist" (please be careful!). Sometimes moving the set to a different location will produce the same effect. If it's still under warranty, call your dealer. Vertical stripes are a common fault with plasma technology I'm afraid! :-( Next time, go for LCD!
Posted on Apr 14, 2007
tvtek
  • 1284 Answers
SOURCE: clicking noise sony bravia kdl-40v3000
It is most likely the cabinet setteling as it is cooling off. Nothing uncommon with all the plastic that is used in TV's.
Posted on Dec 01, 2007
  • 39 Answers
SOURCE: Sony Bravia KDL-40v3000
NISK-TRY USING YOUR DIRECTTV MENU AND LOOK AT THE SCREEN FORMAT SETTINGS AND MAKE SURE YOU ARE AT 16X9 SETTING.JOETV
Posted on Jan 02, 2008
  • 84 Answers
SOURCE: sony bravia kdl-40v3000 blurry news ticker
without going to hd, contrast to full, color, tint and brightness to middle, then adjust sharpness for optimum clarity
Posted on Mar 23, 2008
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
I HAVW SHADOWY VERTICAL BLACK LINES ON THE SCREEN
please let sony know as i have the same probem and they are not acknowledging the problem with this model
Jan 16, 2010 | Sony BRAVIA KDL-40V3000 Television
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
I have a Sony KDL-40V3000 with a single verticle green line going down from top to bottom of my screen on all sources. Otherwise the picture is great. TV is out of warranty so any advice would be very...
This is a fault with the panel or one of the surrounding boards, you need to contact a Sony service center as there is no easy solution.
Just to warn you, it will be costly....!
Thanks
Oct 09, 2009 | Sony BRAVIA KDL-40V3000 Television
Half the screen is black
I think its either the X-sus or Y-Sus Boards which control the display. These are 2 boards with heatsinks on them, lots of capacitors and are at either edge of the screen.
Apr 04, 2009 | Sony BRAVIA KDL-40V3000 Television
Screen too big for mitsubishi black diamond tv
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
Dec 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Green pixel lines
It sounds like a bad LCD panel but you would have to post a picture of the problem for me to be sure
Sep 11, 2008 | Sony BRAVIA KDL-40V3000 Television
Dec 21, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
