Question about Aprilaire 350 Humidifier
My 2004 Aprilaire 350 is cycling on and off every second os so. I assume the water is actually cycling on and off. Kind of a hammering effect. I tied the humidistat wires together to check if it was that? No the problem continued. I 'm just guessing but could it be the solenoid? We have hard water here in the NE could this be causing the issue? I don't mind buying a part, I'd just like to get the one that will fix my problem Don
  • 822 Answers
  • 7 Answers
SOURCE: Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Posted on Feb 22, 2008
SOURCE: Solenoid won't open--voltage drops when connected to humidistat
The coil may shorting out the 24vac supply to the solenoid. Recommend replacing soleniod.
Normally you should be able to read the 24vac across the solenoid when energized.
The other option is to get a 120vac to 24vac transformer and test the solenoid. This way you will know if the solenoid is the cause or the 24vac source is the problem.
Posted on Mar 10, 2009
  • 232 Answers
SOURCE: Aprilaire 600 with outdoor senser, knocks when on
if the wire to the outdoor sensor runs close to high voltage wiring it may cause that
Posted on Sep 13, 2009
  • 232 Answers
SOURCE: Water only runs with humidistat in test/reset mode
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Posted on Nov 29, 2009
  • 744 Answers
SOURCE: Aprilaire 600 problem
It sounds like you got it...
The solenoid will not open with only 13 volts to it. Jump or apply the full 24-27 volts to the solenoid and see if it clicks and opens and allows water to flow.
If the valve still won't open or pass water, start looking for a plugged inlet solenoid inlet screen or a faulty solenoid valve as well as a faulty humidistat.
Posted on Jan 06, 2010
Testimonial: "very helpful, thank you"
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
About half the time the humidifier turns on and within 2 seconds turns off. Combine that with the very loud solenoid or water hammer, it's very annoying.
Sorry to read about your problem, I hope this helps you out.
yes thats the water inlet solenoid, should get replaced
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Aprilaire 700 Humidifier
On my Aprilaire 560 humidifier it says to replace water panel evaporator annually. Are there any documented instructions on how to do this?
Dear Reader,
If you visit aprilaire.com, you can go to the "OWNER'S CENTER" tab at the top of the page. With the cursor on "OWNER'S CENTER", more options will appear. Click on the "OWNER'S MANUALS" option. Scroll down to the bottom of the page and you'll get to a list of our older model humidifiers. Click on the first link which includes your model 560. By clicking on this link, you will be able to download the owners manual for your 560. On page 16 of this manual will be the step by step instructions explaining how to perform the water panel change.
If you have any further questions regarding this or any of our products, please feel free to contact our customer service department 800-334-6011 at your earliest convenience.
Kind regards,
Zach Handyside
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Nov 16, 2010 | Aprilaire 600 Humidifier
Our Aprilaire humidifier has started to make a loud ringing noice. It doesn't last the whole heat cycle but seems to be making the noice for a longer period of time now. What can be the...
The water solenoid valve in your Aprilaire humidifier makes an audible sound anytime it opens and closes. This is normal operation. On occasion a mineral deposit may become lodged in the valve. When this occurs the valve may make a buzzing sound as the plunger is not seating properly. You may dislodge the deposit by lightly tapping the valve.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
www.aprilaire.com
Nov 15, 2010 | Aprilaire 700 Humidifier
Aprilaire 550 clunks on shut off. Never did this before. Changed the saddle valve and Solenoid. Checked copper water line for possible vibration on a pipe, nothing. I'm stumped
Thank you for contacting us regarding the "clunk" sound you are experiencing with your Aprilaire 550. The noise you have described is called water hammer. Water hammer is a pressure surge or wave resulting when a fluid in motion is forced to stop or change direction suddenly. Water hammer occurs when the solenoid valve closes at the end of a humidification call. To prevent the sound of water hammer, we recommend contacting your heating & cooling contractor to install a "shock arrestor" part number 4280. This device is installed between the water pipe and the solenoid valve and will absorb the shock and stop the banging. Please contact your heating & cooling contractor or our Customer Service Department if you have further questions. Kind Regards, Jessica Garrett Customer Service Specialist Research Products Corporation
ww.aprilaire.com
Oct 30, 2010 | Aprilaire Humidifiers
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
Aprilaire 560 constantly drains water
check to see if you have 24 volts between to 2 yellow wires coming out of the water solenoid. if you have 24v, then it is still getting energized to run. if it does not have 24v and the water is still running, the solenoid is stuck open. most likely from water deposits. sometimes you can take the solenoid apart and clean it, but probably better off just getting a new solenoid.
Feb 07, 2009 | Aprilaire Humidifiers
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Lous noise in the furnace when aprilaire 700 on
I have had the same problem , off and on, on my two 700 units for over 4 years. It is caused by water hammer which results when a water solenoid valve closes quickly under pressure. Refer to your owners manual or get a copy of it off the internet. Note the areas where they tell you to remove and clean the inline water strainer and the inline orifice restrictor. These are VERY small components and can clog up easily so they need to be cleaned per the manual. While cleaning them won't totally eliminate the problem it has helped mine with the noise. You really need to have a qualified person, like a plumber, install a small, water hammer arrestor in the inlet line. The trick is to be sure it ends up parallel to the water line flow and not perpendicular to it.... a common mistake. If you are not qualified to work on solenoids and piping, don't do it......it will end up costing you more to repair your mistakes. Good luck
Carl
Jan 03, 2008 | Aprilaire 700 Humidifier
Aprilaire 400 - Mesh Screen not wet
Not happy either. I bought 3 Aprilaire 400 for my house (3 zones). I picked this style since I have attic installation and did not want to run drains. The first night I expected a major air quality improvement but no change in humidity. I have installed humidifiers before so I know the drastic improvement they make. So I watched for a season and still no humidity improvement. Absolutely nothing at all. Same exact observation as you all described. Only the bottom of the media was wet. I'm dissatisfied with Aprilaire 400. Do not buy! Since I installed humidifiers before and understand them I am converting the Aprilaire 400 to work like a Aprilaire 600. I simply unwired the float sensors, removed the floats/lid and using a knife cut some of the plastic cups so the water would drain well. I also cut open the plastic exit port some too so it wont clog from dust globs. I obviously added drains. HUGE RESULTS. On the very first cycle on the humidity in that zone went from 25 to 48. I am watching carefully. -GK
Dec 31, 2007 | Aprilaire 400 Humidifier
Aprilaire 350 Humidifier Logo
394 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
