Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
I moved house & the Tecnik 795/2 dishwasher looks like it has never been used. It is plumbed in, and starts to work, LED comes on, water goes in, but then it all stops and nothing happens. It seems a shame to scrap it, as it is in immaculate condition. Any ideas? I don't think the pipe is blocked or kinked. Regards, Gary
On the control panel there is two black lines which state reset hold both buttons down and the end light will come on -the module will be reset
Posted on Jan 25, 2011
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik Integrated 795/2
Unfortunately you may have lost the controller or if you are lucky just a loose wire. You can get to all of this by taking the door cover off. If it is not a loose wire the control would be my next best guess. Sometimes they just go.
Sep 06, 2012 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I need to remove this dishwasher from the cupboard housing - how do I do it and what problems can I expect
You can expect a lot anything when it comes to plumbing. The water line could be tough to remove to value.. If you don't have any problems of tearing up your dishwasher it shouldn't be that tough. Just make sure you have the water shut off to the dishwasher.
May 13, 2011 | Tecnik TDW2677 Built-in Dishwasher
Miele Dishwasher G664
Make sure the drain line goes up as high as it can then strap under sink, then let it come down to disposal. This acts like a trap so water roll back into dishwasher.
Dec 16, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Water not draining
PLEASE REMEMBER THAT THE MACHINE DOES LEAVE A LITTLE AMOUNT OF WATER BEHIND.AS LONG AS THE WATER IS NOT ABOVE THE FILTER MEANING THE MESH AT THE BOTTOM THERE IS NOTHING WRONG WITH THE MACHINE.GOODLUCK.MOHAMED
Sep 18, 2008 | Electrolux Frigidaire Professional Series...
Water not draining
were is the drain plug located and how do we remove? help
Jan 25, 2008 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Aug 27, 2007 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
190 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Tom Chichester
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
