Question about Frigidaire ATF6000ES Front Load Washer
Shakes vilontly in spin cycle. - Frigidaire ATF6000ES Front Load Washer
    Problem Solver:
  • 6 Answers
This is a known problem with these washers. Kenmore's version is 417.44102300 which I now have the exact same problem with. It bangs loudly on spin cycle and literally jumps across the floor.
We bought ours about 6 years ago. Apparently the bearings go bad and the tub becomes loose inside the washer; also, the "spider assembly" -- the arms that turn the tub -- disintegrate over time and fall apart. These are widely known defects. The manufacturer blames the use of non-HE detergent or "too much" detergent. IOW, they blame you, the user for their use of substandard design and materials.
So, the manufacturer (Frigidaire/Kenmore) will not own up to the issue and do a recall/repair. I have read where some people call Frigidaire / Sears and demand free repair but I doubt this is very successful. You are left with the option of fixing yourself (parts can be had for $200-300 but it is an intensive and very technical repair) or get a "ServiceSmart" contract from Sears for $350 which covers all repairs for a year. And you can hope nothing else goes wrong with this model after repair. I'm not sure if the replacement parts are the same or have been improved.
If the repair exceeds $500, Sears will credit you that amount toward purchase of a new washer. So that gives you a net discount of about $150 off a new washer which you can get from any halfway decent sale at other big boxes or your local appliance retailer. I am leaning toward buying a new washer on sale for about $450 + tax -- not at Sears (had enough of their dishonesty), and not a Frigidaire family product. Looking at washers from Lowe's. Good luck.
Posted on Dec 31, 2010
  • SteveO87 Dec 31, 2010
    I must apologize, mmhall25, I'm not sure if the Frigidaire model ATF600es is equivalent to my Kenmore model above, but if it's a Frigidaire front loader from about 5-7 years ago, it likely has the same parts and problems. I hope my reply was helpful to you nonetheless.
Where is the fuel filter 2000 chevy blazer 4.3 LS
should be on the drivers side near center of frame
Mar 14, 2010 | 2000 Chevrolet Blazer
Washer was making a very loud shaking sound in the spin cycle, the noise stopped the spinning stopped and I smelled burning.washer will not spin
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 27, 2010 | Frigidaire Washing Machines
Spin cycle problem
I had the same problem you need to pull out your washer and observe which leg is uneven this should be the source of your shaking and if you use the proper tools you can solve this.
Dec 31, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Spin cycle - washer is shaking and jumping
Try to relevel the unit. Another suggestion is use the cycle for delicates (the spin cycle is slower). If it is still out of balance and shaking one of the dampers may have broke
Aug 17, 2009 | LG WM-2277HW Front Load Washer
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Washer shakes on spin cycle
2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
2 check the suspension legs at the base of the tub for wear or damage.
Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
204 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
