Question about HP Color LaserJet 2600n Printer
MAGENTA TONER IS FADED
HI WHILE PRINTING, THE MAGENTA COLOUR IS FADE BOTH ON THE RIGHT AND LEFT HAND SIDE. ITS ONLY THE CENTRE WHICH SEEMS TO HAVE SOME COLOUR. HAVE REPLACED TONER WITH THE ORIGINALS AND YET NO IMPROVEMENT.
  • Anonymous Jul 10, 2008
    when printing, magenta is very light pink in colour instead of the red colour selected.i use only original cartridges and have tried three already.i"ve cleaned the scanner mirrors but still the same.
  • 15 Answers
This problem is a fairly common one and it is a tough fix. The laser unit has 4 lasers inside that shine off mirrors. The magenta mirror is on the bottom facing up and so gathers the most dust. The black mirror also faces up but is higher up and seems to not collect as much dust but it can experience the same problem. If you go to this HP forum
http://forums12.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1216658405809+28353475&threadId=1230246
you can read about the problem. Also you can search ebay for HP 2600 MAGENTA REPAIR and find a solution.
Posted on Jul 21, 2008
  • 81 Answers
Try to calibrate your printer. also try to change your drum unit.
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Dell 2135 fading left side when printing
It's possible that this could also be down to a toner cartridge inside the printer. I would recommend running off a copy of the colour laser test page found here.
The colour bars towards the bottom of the page separate cyan, magenta, yellow and black. Hopefully you will be able to notice that one colour is affected more than the others and replacing that colour may help.
Apologies if you have tried anything similar previously.
Oct 31, 2012 | Dell Office Equipment & Supplies
OKIC5450 . in portrait Left side fades off (about 2") in all colours but worse in black. All drums over 50%, Fuser 100%, All toners at least 39% belt 22% colour page count 38000
When you touch the faded side with your hand after the paper comes out of the printer, does the toner come off on your hand? If so, it's the fuser. If not, it's probably the transfer belt.
May 27, 2011 | OKI C5100n Laser Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
The Magenta colour on my 2605dn is no longer coming out properly (very faint). The cartridge was replaced by made no difference. All other cartridge colours work fine. Tried cleaning and calibrating but...
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
HP1600 colour fade on one side
it will most likley be the drum take it into a printer shop and they will clean it befor it gets to damaged as they are hard to replace
May 28, 2010 | HP LaserJet 1600 Printer
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
HP Color LaserJet 2600n Printer Logo
476 people viewed this question
Seeker5211
Seeker5211
