Question about Acer Aspire One PC Notebook
Works great for about 5 minutes, then it freezes, then after about 30 seconds theres a long steady beep
    Sergeant:
  • 169 Answers
The First thing i will advise you to do is to FORMAT your system and Install a fresh Operatinf System on the System..
Remember to Rate me
Posted on Dec 31, 2010
5 short beeps when the engine is killed
the beeps are to tell you that there is something not working propaly in the car engine just take it to sume were that can reset the dieanostics for you
Jan 14, 2016 | 2000 Kia Sportage
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
Is it possible for the new brake light switch i got from NAPA to be bad? It worked for about 5 minutes then started to beep again when i got up in the AM. now it sometimes works for like 5 seconds then...
It's possible but not likely. I would check the wiring to it, next.
If it is bad, then take the switch back to NAPA, and I'm sure they will replace within 30 days or so.
Sep 24, 2010 | 2005 Chevrolet TrailBlazer
There is a beeping sound that I cant diagnos. It
Someone may have lost a digital watch in the vehicle. Or you may have an alarm feature for a destination timer. See if the clock has a setting for repeat alert.
If you have an owners manual see what features you have for the trip computer or navigation unit. On the menu for the Command Control you have controls for the Horn to blow for setting the alarm, Park Assist, and Autolock for the doors. It may be on that menu for a clock alert.
Mar 27, 2010 | 2002 Mercury Mountaineer
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
May 29, 2009 | Magellan Maestro 4250 GPS
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
30 Seconds High Beeps with Hazzars
The battery is low which is causing the alarm to activate, replace the battery. I'm going to guess that it gets pretty hot where you are between the times you listed. BMW cars have been known to be affected by heat.
Dec 17, 2008 | 2001 BMW 5 Series
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
