I recently purchased a Canon MF 4350d printer/scanner/copier. I have Win 7 (32bit) o/s on my system. I installed the drivers that came in the package, and later also downloaded from canon site. The scanner is shown in device manager under imaging devices. Even from 'printers & devices', when I click on Canon printer it shows scanner properties. Yet, the scanner does not respond on 'start' button press, nor does MF toolbox 4.9 detect the same. Always gives an error that 'compatible scanner not installed.... please install a compatible scanner and then restart toolbox' Kindly help out
    New Friend:
  • 97 Answers
Was the driver that you installed for 32bit or 64bit?
Posted on Apr 20, 2017
SOURCE: Canon MF 4350d Wont install
Same problem with Dell 4600C. Tried to connect new Canon Imageclass 4350d monochrome printer. First spoke with Canon technical support for 45 minutes (this is after I spent several hours on my own trying to resolve the problem) and after installing, uninstalling, and installing Canon drivers from disc and online from Canon, same problem: "USB device not recognized". Canon said it must be a computer hardware or software problem with my Dell computer. I then called Dell technical support and was on phone for three hours. They had same problem and suggested I do a complete restore using the Windows XP operating disc that came with the computer when I purchased it in 2003. After doing this time consuming measure, same problem. Dell told me that it may simply be that the Dell 4600C computer and the Canon Imageclass 4350d printer may not be compatible. Both Dell and Canon suggested I try to hook up a different computer and see if the drivers will load correctly from the Canon disc so that the computer will communicate with the printer. Will try this tomorrow, but even it the printer then works, this doesn't solve the problem with using my Dell 4600C computer with this printer. If this is the case, too bad Canon doesn't inform the public about this incompatibity issue.
Posted on Sep 21, 2009
  • 151 Answers
SOURCE: import windows contacts as address book fo MF 4350d printer
Being the canon will import a .cvs file you need to export the windows contacts folder into a .cvs file and then import it into the canon.
To Export the windows contact file to .cvs file (from Microsoft webpage)
To export contacts so they can be viewed by someone using another program
You can convert all your contacts at once to the format you choose so that someone using another program or a previous version of Windows can open and view them.
  1. Open Windows Contacts by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, and then clicking Windows Contacts.
  2. On the toolbar, click Export, and then click one of the following formats:
    • CSV (Comma Separated Values). This is a generic file format used for exporting or importing information to and from databases or spreadsheets.
    • vCard (folder of .vcf files). This format is used by many other programs. It is typically the best format to use when sharing contacts with someone who is using an earlier version of Windows or who is using a different operating system.
  3. Click Export, select a folder where you want to store your contacts in the new format, and then click OK.
  4. When a message appears telling you that the contacts export process has completed, click OK, and then click Close.
To import the .cvs file into the Canon 4350
open a document and select the Canon 4350 fax driver as the printer
Select the Edit Address Book TAB
Select Import TAB
Browse to where you stored the exported .cvs contacts file
Click on the .cvs file to be imported
Click open
It will process and the address book will them be populated withthe data from the windows contact folder.
Posted on Feb 11, 2010
SOURCE: canon mf4350d WONT scan out of the box
The software that comes with Canon MF4350 does not detect the absence of WIA service running. If printer is working and the correct driver is installed, the first thing to check is: 1. Check that the scanner does NOT appear under Control Panel -> Scanners and Cameras. 2. Navigate to Administrative tools -> Services (the same menu is available under My Computer -> Manage -> Services. 3. Check that service "Windows Image Acquisition (WIA)" is enabled and started. 4. If WIA service is not enabled, enable it. The scanner should appear under scanners menu (see 1.) and Canon MF4350 should work fine.
Posted on Apr 04, 2010
SOURCE: canon mf 5770 problem : opening the mf toolbox
I have the same problem. You can't use Canon Toolbox 4.9x. It does not work. You will have to download and intall the x64 driver only from the Canon website for the MF5770.
Unpack the x64 driver and install it.
Go to the Start-menu and click on Units and Printers. Right-click with your mouse when hovering over the printer, then choose scan, fax or print.
We can only hope that Canon will solve the problem in the future, most likely not since MF5770 is an older Multifunction-machine.
Posted on Apr 21, 2010
SOURCE: my canon product mf 4350d having an eror e225 how
can't start properly
Posted on May 01, 2010
Where is the hard drive located
MF-4350d does not equipped with hard disk.
Sep 02, 2014 | Canon imageCLASS MF-4350D - 23 PPM...
Scanner CCD sensor
system error e225 Sir, there is an error i.e system error e225 in my canon mf 4350d machine I cn,t copy more then one time please help me shut out this problem
Jan 29, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
Systemerror e225
Cannon imagecalss mf4350d E225 error solution please ..tell me
Oct 11, 2012 | Canon imageCLASS MF-4350D - 23 PPM...
I haven't CD installation and want to need canon imageclass MF 4350d
You don't need the disc to start using your printer. Go here
and click on "drivers and software" button. Select your operating system and download the driver. Then you can use that driver instead of the disc that came with the printer.
May 19, 2011 | Office Equipment & Supplies
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Almost the exact same problem. New 4350d Canon printer trying to connect it with Dell 8300 with XP. The computer says it does not recognize. Tried everything - reinstall drivers, download drivers, tried every USB port, swapped cables, spoke with Canon support and finally took the printer back and got a new one (Canon support person decided the USB board must be bad). New machine - same old problem.
Feb 10, 2009 | Office Equipment & Supplies
209 people viewed this question
