Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I have a noise comming from the lamp area the fans are working fine i think it is the lamp do they make a noise when they are anout to break
  • Samsung Master
  • 6,694 Answers
if the sound is not coming from the fan then check the connections of ur lamp, if there is any loose contact in the connection there will occur a sound. also fan will produce some noise if its bearing have some problem. it will work fine but produce noise. the lamp will make noise at the starting time afterwords it will not.
ok
Posted on Dec 31, 2010
Projector makes lots of noise
Yes, that can solve the problem because there's also a possibility that the lamp is the one that is causing the noise..
Hope that helps........
Aug 18, 2008 | InFocus ScreenPlay 5700 Multimedia...
Fan issue with hd-52g787 52 inch
The lamp is protected if fan does not work it has a thermal fuse that will cut power to lamp etc.
One of the real issues is the fans intake air from front of set and exhaust it out rear---sets and fans get coated with fine dust and cause problems including in some cases set shutting off.
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
Cooling Fan for Lamp 50V500A
If you wish to get some details; visit the site linked here. Pull up older posts.
Lamp replacement procedure to projection TVs are given.
Apr 26, 2017 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a wd52628
This area of the TV is a cause of some expense in rear projection.
The fan controls the temperature of the lamp. An obstruction keeps the fan from coming up to speed.
The power block controls the power the lamp uses. This helps keep the glass of the lamp from breaking breaking.
An arc is a badly mounted lamp or a lamp defect.
Dust build up can cause overheating.
Most of this area cannot be serviced by a non-technician.
Apr 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Set was working well before being placed on top of an amp. After about 2 hours of operation it quit, with 3 flashing lights. Ballast and Lamp fans work fine, lamp was replaced and ballast was replaced, no...
make sure all cables . connectors are seated at their right place.make sure lamp is secure and closing lamp switch .lamp door switches are closed .
Aug 06, 2009 | Samsung Televison & Video
Tv turns on but turns off after anout 30 seconds
I think your TV is a projection. Your lamp is already exceeded the require total amount of light can be use. You need to replace the projection lamp. Thats why you have a temp light on.
Jul 23, 2009 | Samsung HLM507W 50" Rear Projection HDTV
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
