Question about Bunn NHB Coffee Maker
Not working My Bunn worked yesterday Not working this morning
  • 189 Answers
Did you check the switch on the side of the machine to make sure the "l" is in the down position and the "O" is up and you see orange around the switch? If not, then please make sure the switch is in the right position. If this doesn't correct the problem, then please call customer service with your model and date code. The machine carries a 3 year warranty and if the machine is less than 3 years old, we will replace it at no cost. If it is over 3 years old, it will be replaced at a reduced cost.
Posted on May 19, 2010
Can I leave my bunn vpr plugged in at all times or do I need to unplug it each time after use?
Good. Morning
My rule of the thumb is to leave all electrical appliances plugged at all times, when I am at home, when I travel I unplug everything. The TV!, DVD, coffee machine and so on. I usually leave one radio on.
So when I come back there is live in the house.
this has worked well for me,
all the. Est
Kolbrun
Jan 30, 2015 | Bunn Coffee Makers & Espresso Machines
No sound
TV was working okay yesterday The screen is showing no signal when I turned it on this morning, I check the cable hookup
Nov 19, 2013 | Olevia LT42HVi 42 in. LCD Television
Water not getting hot anymore
by 'reset' do you mean that you moved it, tilted it, shut it off and back on?
Mar 06, 2013 | Bunn CWTF 15-APS Coffee Maker
Clear water leaks on the counter between morning and the next morning.
it must be overflowing.Its not leake.
check that if you totally turn the machine off for 2 days .The water still leaks.
If yes then replace the water inlet solenoid.
if not then check float sensor that its working properly.
Thanks
Please rate my work
Sep 17, 2011 | Bunn B10 Coffee Maker
My 2 year old Bunn coffee maker was working last night but I went to make coffee this morning and the water was not hot, the switch on the side was off and the warmer wouldn't come on. I tried another...
Most probably the relay that drives both the heating element and the warmer.
A black thing like little box (relay)that containes 8-6 wires (2 from main board and rest just go other components.)
Thanks
Please rate my work
Sep 17, 2011 | Bunn NHB Coffee Maker
Describe your 10-Cup Home Coffee Brewers Problem I have never had any problems with my bunn coffeemaker.This morning I turned it on and it did not work,the swith on the side is on red,any suggestions?
When you click brew is that making clicking sound If not then check Inlet solenoid Voltage at inlet solenoid once you hit brew button Chek the switch is working If you know how to use multimeter then only you can do this things otherwise just leave the answers here Thanks Please rate my work
Sep 03, 2011 | Bunn 10 Cup Home Coffee Brewer
I have a Bunn coffee maker (Model NHB code date154704) that trips the ground fault breaker the second you plug it in. It worked fine yesterday, but last night my wife put half water and half vinegar in it...
The water doesn't come into direct contact with the heating element. The only way to know the cause of the problem is to use a multimeter and test the circuitry.
Sep 28, 2009 | Bunn RL Coffee Maker
My 2006 Bunn blows a fuse when used
This sounds like a short in the main heating element. If you are within your 3 year warranty, Phone Bunn and talk to their warranty department. They will give you a RMA number and give you further instructions. If not, there are no replacement parts available for these brewers.
Sep 29, 2008 | Bunn NHB Coffee Maker
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker not working
My warm indicator light is not working. Only used less than a month.
Nov 15, 2007 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
49 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
