Question about Frigidaire ATF6000ES Front Load Washer
I am having a problem with the water not coming on when I engage the the knob. It shows the door lock light is illuminated. It just has a humming sound..
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Sounds like you "water inlet valve" is faulty. Replace the valve with this part.
Posted on Dec 31, 2010
Washer didnt drain all the way and now i keep gettin a code. n the light for the door lock wont come on
If water is in tub and the control tries to drain tub but water doesn't drain, then the unit will not operate. Most LG have a drain pump clean out located behind the access door on lower side of washer. Open the door and you will see a black tube with a cap and a round knob. First, get a bucket, pull the black tube slightly out and remove cap. The water in the tub will start to drain and you may have to fill bucket many times to get all water out. Next, unscrew knob and a little screen will pull out. Inspect this screen and inside of pump chamber. Your looking for any thing that could block the pump. If pump hums and still doesn't drain, the drain pump is more than likely bad. Good Luck
May 25, 2016 | LG Washing Machines
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
No water coming into washer and washer act like it don't want to come on
Be sure that the valves are turned on. Does the door lock engage? Does it hum when it is trying to fill?
Oct 17, 2012 | Washing Machines
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
My washer will not drain but everything else is working on it can u give me instructions?
most of the time it is the door switch that gets damage when the door slams. if its only fill with water but not turning then it is defently the door switch.
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Knob doesn't advance
Hi, the timer is malfunctioning. you will need to replace this device. i have provided a link below to the actual REPLACMENT part you will need.
CLICK HERE TO BE DIRECTED TO THE REPLACMENT TIMER
Apr 16, 2009 | Washing Machines
My kud101flss2 will not start
First be careful about electrocution-did one of the wires come loose underneath-but don't touch anything. Check to see that it is plugged in and also that the fuse is not blown or breaker tripped. If this does not resolve the issue, if not hardwired, check for a tripped outlet and try another electrical item in the outlet to be sure that power is going to the outlet. Another posibility is that for some reason the door is not locking and allowing the knob/dial to engage. Open your dishwasher and look at the top of the door-does the bar come across when you lock it? Keep it open and turn the knob all the way around to the end of cycle position. Close and lock the door and try again.
Mar 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Frigidaire ATF6000ES Front Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
