Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor width distorted
The display of my monitor has got shortened about 1 cm on left and right. the osd menu shows width setting at 100. what can i do?
    Problem Solver:
  • 8 Answers
Components in the deflection circuit CHECK those.
Posted on Jul 08, 2008
I can't get my icons and taskbar to center on my monitor. The start button is off screen to the left. How do I center everything so I can access them?
Press the OSD (On Screen Display) button on the monitor.
Use the UP/DOWN and LEFT/RIGHT buttons to navigate through the menu, to get to the "horizontal position" menu.
Press the OSD button to "select" that setting.
Press the LEFT/RIGHT buttons to "move" the image LEFT/RIGHT.
Press the OSD button to "apply" the new location.
Wait a few seconds, and the OSD menu should close itself.
Oct 24, 2010 | Microtek 815C 18" Flat Panel LCD Monitor
Tip
Diagnosing video problems on TVs and monitors
The first thing to always check is the MENU (osd - on screen display)
Push menu or display on your tv or monitor
- if the menu is clear, the problem is in the early stages of video or outside your device (could be the source (dvd, cablebox) or input connections
- if the menu is distorted, the problem is definitely a malfunction with your device the osd is generated from (tv menu distorted = 100% tv is problem)
* you can also use other OSD signals to troubleshoot - if the volume bar or display info (input label, info bar) is clear, problems are earlier in the circuitry or outside the device. don't be fooled by translucent menus or cablebox menus.
** osd is inserted in the picture in the later stages of video processing. if your osd is distored, suspect the circuitry after the video switch. this could be a bad LVDS cable, TCON or Logic board, or even a bad lcd panel, plasma panel, crt.
on May 21, 2010 | Televison & Video
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
The language on my menu has changed to Russian. How do I get it back to English
Press one of the buttons on the monitor to activate the OSD (On Screen Display). Wait about a minute -- the OSD probably will cancel itself, if you've pushed the correct button.
Then, use the other "left/right" or "up/down" buttons to navigate through the various settings (contrast, brightness, et cetera) until you get to the "language" setting. Press the "accept" button to select it.
Press "left/right" or "up/down" until 'English' is displayed. Press the "accept" button to choose that language. Then, wait a few minutes, for the OSD to "self-cancel".
Apr 24, 2010 | LG Flatron L1750S 17" LCD Monitor
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
Mar 07, 2010 | HP M700 Monitor
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
Display width distorted
This could either be a problem with the horizontal width circuitry (either a capacitor or a resistor or even a diode pair) or a filter capacitor in the power supply.
You could try lowering the screen resolution of your computer's desktop properties.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 08, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Philips 109s20 crt monitor
Here's the link for the product support page; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=109S20&scy=us&slg=AEN&grp=PC_PRODUCTS_GR&cat=CRT_MONITORS_CA&sct=CRT_MONITORS_GT19_SU Click "User Manuals" on the left. or here is a direct link; http://www.p4c.philips.com/files/1/109s20/109s20_dfu_eng.pdf Check page 28: "The Main Menu displays OSD MAIN MENU LOCKED . Pressing the front control panels hasno effect. How can I unlock this function? Press and hold the OSD menu key for about 10 seconds until picture displays "OSD MAIN MENU UNLOCKED"" Hope this helps :)
Sep 03, 2007 | Philips Brilliance 109S Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
