How to fix a samsung sdt-7000 plus freeview box that won't turnbon
Ive lost the codes for my remote can someone help me please
Go here to download the .pdf file. It will guide you in finding the right code for your product. https://www.u-manual.com/download-manual-now-for-free-10/135629/remote-commander-remote-control-one-for-all-urc-3920-ofa-2.html#.Vb5uWG5VhBd
Aug 02, 2015 | Toshiba Televison & Video
Bush freeview plus code
Just do a code search method. If you wish to get more details, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 29, 2013 | One For All URC 7740 Remote Control
I can not set up my freeview on my samsung 52 inch LCD can u help me step by step as I hav no instructions thanks
Plug your aerial into the freeview box. Connect a scart lead from the freeview box to your TV and switch on.
The freeview box, if new, will search for channels itself and as your TV will recognise that it is plugged in, will auto switch to the freeview box.
If it is not new, select menu on the freeview box and follow the instructions for tuning.
There is nothing to tune on your TV as you are using a scart lead.
Hope that helps.
Nov 14, 2010 | Televison & Video
Samsung LE32N7 - Analogue channels ok - Freeview set top box ok- Tv's own digital tuner stuck on one channel (BBC1) in freeze mode - and won't unfreeze. Cannot access DTV menu- does not reset on power...
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Sep 17, 2010 | Samsung Televison & Video
Freeview is not working on my samsung tv normal tv is ok freeview not working since 30-09-09
Freeviw not working on my Samsung LA40A750D but did work through a free view box on another tv previously
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
42"lcd samsung tv,one year old has stopped working on digital and analogue but can work with a sky box or freeview box,ie it will not work on its own,thanks 42" lcd samsung wont work without a sky or...
sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Sep 04, 2009 | Samsung PPM42S3 42 in. Plasma Television
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
I HAVE A HDD&DVD PLAYER RECORDER WITH DIGITAL FREEVIEW IT,S DVDR5520H.I IT DOSE NOT DOWNDOAD THE PROGAMMES PLUS GUIDE. CANYOU HEHP
in setup for guide plus U must enter the time and date along with UR correct post code and select freeview as UR input then the correct input route of UR freeview box ie EXT2 then proceed as instructed. also you must select program number 102 on you freeview stations for the eye to send signal to UR box .the eye for the guide plus must be placed directly in front of the freeview box by it`s remote control reciever.
Oct 08, 2008 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
