Question about Lenovo ThinkPad T61 Notebook
Lenovo T61 keeps shutting down for no reason. Repair shop took out fan and checked it, works fine. They also blew out dust from vents. Problem still there. I installed a CPU temp utility pgm and shows temp at about 50 deg C when it shuts down. What could be causing this?
    Guru:
  • 679 Answers
Automatic shutdown is always cause of overheating, busted heatsink/ fan/motherboard. if the fan and heatsink wasnt replaced yet though they check it fine i would still recommend replacing it. if the problem persists a mainboard replacement would be the last part needs to be replaced.
Posted on Dec 31, 2010
Lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 24, 2012 | Lenovo IdeaPad Z560 Laptop
My lenovo ideapad z560(core3i,2gb ram) keeps shutting down automatically.... havent been able to identify any specific reasons for it.. sometimes its stuts down just after bootin...or jst in d middle of...
I suggest try to check these things on your machine.
->Check if the machine is Overheating.
->Check which part of the machine is Overheating.
->See if the Fan of the machine is Running(Feel if the air vent of the machine)
Cause of Automatic Shutdown:
-Memory
-Hard Drive
-Fan is not working
Most likely those are the cause of the machine keeps on shutting down unexpectedly.
Apr 12, 2011 | Lenovo IdeaPad Z560 Laptop Computer -...
My acer extensa 5420 keeps shutting down like its over heating but i do not think it is over heating due to the fact i have 2 cool down fans on my computer(you set laptop on it and two fans blow on the...
Shut the system off, remove the battery and unplug everything. Blow through all the air vents with a can of compressed air. Keep blasting air in there until dust quits coming out. The reason I offer this suggestion is because it sounds like the system may be overheating, as you described. The cooling fans are great, but if the heatsinks get totally clogged with dust, the fans can't remove the heat as quickly. I don't know that this will fix your problem, but it's really easy and cheap to try, and a good place to start.
Feb 28, 2011 | Acer Extensa 5420-5687 Notebook
Re my Thinkpad T61: Last weekend it froze. Icons would not respond to mouse clicks. Could not open new programs or close the programs that were open. Pointer was still working -- it just did not work to...
There are a couple of things that can go wrong with it. The most common thing on laptops is overheating.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner
If it is not overheating, then it is a hardware failure. Could be the RAM memory, processor or the motherboard. You can test the RAM with this program: http://hcidesign.com/memtest/MemTest.zip
If RAM is ok, then only replacing hardware equipment could corner the problem.
Dec 15, 2010 | Lenovo ThinkPad T61 Notebook
I have a Lenovo T61 ThinkPad. Now it shuts down after starting up. Upper left hand says, "FAN Error". Do I need to replace my fan drive?
Open up the casing and inspect the fan(s) and any ventilation grilles, removing any build up of dust where present. Put it back together and restart the laptop.
If this doesn't work you could purchase a replacement fan and fit this to the CPU.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 21, 2010 | Computers & Internet
Long continuous beep on a t61 while in windows not
Check if the system is overheating.
You can try to clean the cooling vents using a can of compressed air or a vacuum cleaner (make sure to turn off the system and disconnect battery and charger before you try this).
If the processor heatsink/fan assembly is clogged with dusts, it can cause this problem.
You need to make sure that the processor heatsink/ fan assembly is clean of any dusts.
The following link will give some idea about how to clean the heat sink
http://www.laptoprepair101.com/laptop/2006/01/04/toshiba-laptop-overheating/
(it is for a different make/ model, but the principles will be same.)
Mar 09, 2010 | IBM Lenovo ThinkPad T61 Notebook
Lenovo Y410 auto shutdown
go to system properties & disabled system auto restart
Aug 30, 2009 | Lenovo 3000 Y410 Laptop
Lenovo t61 shut down w/out warning. Could it be
When the laptop is conected to the mains adapter and it shuts down for no reseason and you can boot up again after a period, it would indicate that you could have an overheating problem.
Check the fan to see if it spins freely and there are no dust clogging the fan and heatsink assemble, remove and vacuum the dust, if the fan is faulty, replace it.
Jun 18, 2009 | Lenovo ThinkPad T61 Notebook
Laptop shuts down
HI- I have one and it shuts down to. For us it was a problem with overheating and dust in the laptop. I beleive there are heat sensors inside the laptop that go, so that could be it. For the most part, when it shuts down, we have found it to be dust as after we clean it, it doesn't happen as much. For the dust- the first time blew air into the fan outlets (both of them) and a ton of dust came out. Sounds simple, but it worked. A tell tale sign may be if your laptop sounds louder than it normally does. We use the compressed air can every so often and even just put the vacum nozle over the fans (you'll hear them whirl and see dust coem out). I also have the lap top sitting on a "vent filter" like people use for thier heting/ac vents (WEB Electrostatic Vent Filters).They come in 4x12 sheets and are cheap. The fans **** up a ton of dust and this helps keep some of it out. Good luck...Steve
Apr 14, 2009 | Toshiba Satellite A75-S229 Notebook
Runco Cl 610 keeps shutting down
on the cl-610 it would shut down after about 5 minutes of running..as well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
Nov 27, 2008 | Audio Players & Recorders
Lenovo ThinkPad T61 Notebook Logo
752 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
