Question about Acer X203H bd Monitor
Screen turns into colored diagonal lines have to unplug and reboot to get rid of them
    Problem Solver:
  • 13 Answers
If you still have the receipt take it down and get a new one. If not I don't know what to say.
Posted on Dec 31, 2010
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
How do I get rid of diagonal lines across my Mag. HDTV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 06, 2014 | Magnavox 19MD359B F7 19 in. HDTV
The screen will have lots of mostly gray vertical lines, can't get rid of these lines
Sounds to me like the LCD screen is going out. Now, it could also be the graphics board/chip on the laptop but I don't believe so in this situation.
If it is the monitor (and I suspect it is just that) then you'll need to replace it. I highly recommend ScreenSurgeons.com for replacement screens. I have used them several times and have always had great support. They have videos with step by step directions on how to replace the screen yourself.
Here is the link to the screen for your model of laptop:
Screen Surgeons
Jan 02, 2014 | Acer New C7 C710-2847 Chromebook 11.6"...
Diagonals lines appears on screen and becomes more brighter
With HV variation the color will not be good. Sometimes I have heard that the screen resistor causes this.
Dec 29, 2009 | Konka K2568U 25" TV
Balck color turns into green
are the dots appearing in diagonal lines or randoml across the screen? This would suggest to me either a loose connection in your cable or the screen is faulty and will need replacing. Sorry for the bad news
Oct 25, 2009 | Computers & Internet
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Dell XPS M1710 - Screen flickers at times when playing games
hi,
reboot your system and at the blue dell logo tap the F2 Key, and now you will be at the bios screen
check if you get these lines at this screen on the screen and if you get these lines here as well, you might have a hardware problem call dell technical support for this, they will run a few diagnostics and if needed replace the faulty hard ware.
further Queries are welcome
Feb 18, 2009 | Dell XPS M1710 Notebook
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Diagonal lines on upper 1/3 of screen
It sounds like the dmd board may be defective but you can try rebooting the set and see if it makes the picture any better...
1 - Turn on the Tv.
2 - Press & Hold the up arrow key on the remote and then press the power button on the front of the Tv.
3 - Tv will reset & reboot
If the picture is the same it's probably the dmd board which is part of the "B" block assembly and I don't believe they're sold separately. The "B" block is about $1100.00 dollars.
Hope this helps!
Bill
Apr 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Acer X203H bd Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
