Question about Starbucks Barista Burr Grinder
I need to replace the Faucigny Instruments (Type M13) time switch in a Starbucks Barista Burr Grinder. I am in Toronto Canada - is there a 'local" supplier available in my area.
  • 3 Answers
SOURCE: INSTRUCTION MANUAL
http://www.saecoparts.com/SaecoItaliaEspresso.html
Posted on Nov 29, 2008
  • 1089 Answers
SOURCE: Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Posted on May 26, 2009
  • 1089 Answers
SOURCE: Super espresso machine leaking
Hi
Your steam manifold needs to be replaced. I still have the original in mine but if you don't cool them down after steaming they will develop hair line cracks and leak after while. To cool it down after steaming push the steam button again, then open the knob and run it till you have a steady stream of water, then close the knob.
The replacement manifolds are black and have held up very well but they have a brass manifold re[placement but you will need new mounting hardware.
Posted on May 31, 2009
  • 12 Answers
SOURCE: carafe for starbucks barista aroma grande
I think I have a fix for the lid. I need a couple people to send me their lid to see if my fix works. My fix does not involve any material destruction of the lid. I will send you the lid back regardless of whether the fix works or not.
Send me a note at ccvoter@live.com and I will give you an address to send it to.
Posted on Dec 24, 2009
SOURCE: I need a replacement lid for the thermal carafe
In your manual there should be a number for parts ordering. I had the same problem. The part apparently costs $30 but because I live in Vancouver, Canada, the kind gentleman at Starbucks offered to send it to me free of charge as the duties at our border/customs would inflate the cost big time. I was very surprised that he was so willing to do this. Keep in mind though, I bought the machine and it was near $200. Very expensive for a drip coffee maker.
Hope this helps.
Posted on Jan 20, 2010
I have Barista grinder. I've had grinder for about 3-4 years and it stop moving. I unplugged cord, tried to turn the feeder and plugged in still not moving except timer is clicking. I wonder why it...
Hi It could be the timer switch but if you hear the timer move(whirring) it is probably OK. There is a thermal fuse on the motor that will go out and you just have to replace the thermal fuse. Its under the wrap on the side of the motor. Which grinder do you have?
Jul 07, 2011 | Starbucks Barista Burr Grinder
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
Electrical cable burn and grinder stopped working Should I replace thermal fuse.
If the wireing burned, you should replace it as well as the diode.
Feb 15, 2011 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Timer switch is not working stuck in the on postion
I just had the same problem. It's the knob itself. You have to extract the knob by pulling, gently, and squeezing it out. The plastic housing over the metal thing is cracked. I took some super glue and duct tape and wound it tightly around it and pushed it back it and it works.
Dec 13, 2008 | Starbucks Barista Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
197 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
