Question about Toshiba Computers & Internet
Toshiba a45 s359 freezes when the onboard card reader starts. I have to shut down and reboot to get away from the freeze.
    President:
  • 1,812 Answers
b>I think it could be due to virus activity. Some virusmake the contents of the drive hidden, that's why user can't see the files and the space available for use is less than thecapacity and also can not open the drive. It issuggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may showthe hidden files. If can not show ,hidden file (tools >folder option>view> check on show hidden file>check off hide protected and checkoff hide extension) now can see all hidden file in c drive. If not think...... For ensure again run>type> msconfig > hit can not open ms config if virus effected run >type> regedit>hit>can not open registry if virus effected run >type >gpedit.msc>hit can not open group edit policy if virus effected Otherwise, ifyou don't have any vital data on the drive, just format it in another pc.Pleasenote, before insert the Pen drive .Go to run command from start menu OR Press Win key+R and type gpedit.msc and hit>Usser configuration >system>turn off auto play >enable>use down arrow key select all drive >apply >ok. Control panel>administrative tools > service>select any word in right side and presss for select Shell Hardware Detection> d -click >use down arrow key>disable >start. And now can insert pen drive and format. Hope this wouldfix the issue and . Youshould fully scan by f-secure bootable cd or any another antivirus bootable cd.Just insert the disk and restart. Follow bellow the download link. http://www.askvg.com/download-free-bootable-rescue-cds-from-kaspersky-bitdefender-avira-f-secure-and-others/ you wouldbe able to enjoy the full capacity of the disk. Try to be sure follow these youshould delete partition and create new partition and format your all drive. Now install fresh O.S.Hope it will help you.
Posted on Dec 31, 2010
Phone "freezes up".
You may have a handset that has a small size onboard memory. Try deleting some of the non-important applications. Then buy an SD card..assuming your handset has an SD card slot. Reinstall the deleted Apps again and save it ti the SD card instead of the phone memory.
HOo to settings - Applications - Scroll through and delete applications that you have installed. DO NOT DELETE ANY SYSTEM FILES.
WORST CASE SCENARIO is to do a factory reset. Make sure the battery is fully charged.Go to settings - Security - Factory reset. The phone will shut down and reset to factory settings. When phone reboot, all installed Apps will be deleted and the phone will only have the Apps that it had or should have at the time of purchase. You will then be able to insert your SD card and install additional Apps to the SD card.
Hope this helps.
Dec 29, 2017 | Samsung Cell Phones
Built in card reader freezes up the computer when it is used . Toshiba Satellite A45. laptop.
Could be some dust got in and is causing a short? try using a toothpick to dislodge any such. Also check Device Manager (Right Click on My Computer/ Properties/ Hardware and if there is a Question Mark on one of the devices click there and reinstall the device.
Dec 31, 2010 | Toshiba Satellite A45-S121 Notebook
Screen freezes at start up and i thin it is a conflict with memory card reader. What does the reader look like inside the hp desk top 320n
it typically plugs into the motherboard at one of the onboard USB connectors. If you think the memory card reader is the cause of your problem, open the case, unplug it and try to reboot with it unplugged.
Nov 28, 2009 | HP Computers & Internet
I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Sep 06, 2009 | MSI PM8M-V Motherboard
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Sep 01, 2009 | Toshiba RS-TX20 DVD Recorder
Toshiba Laptop keeps freezing and shutting down
its the problem of your RAM not the hard disc. the blue screen error come because of less memory available for proccessing. so please once remove the RAM and again insert it and reboot your laptop......
Feb 24, 2009 | HP Pavilion dv6000z Notebook
Camera freezes
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, or shutting down.
Hope this is of some help. Bud
Mar 14, 2008 | Logitech Quickcam Chat Webcam
Laptop doesnt start
there must be a problem with the voltage output of the adaptor... because many modern laptops react by shutting down when they encounter voltage ranges that they r not supposed to...
Feb 01, 2008 | Toshiba Satellite A45-S151 Notebook
Computer constantly freeze up!
apply heat sink paste in your processor
heat problem
Oct 27, 2007 | Toshiba Satellite A45-S151 Notebook
Computers & Internet Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
